So today taiwo brought his car over to assess his limp mode situation - i managed to extract the 61 'engine' code which is "61 Communications wire with A/T-ECU"
I also managed to get what is hopefully an unrelated TCL error code out - which is reading as 14 (which has to be wrong as there is no code 14 for the TCL) It was flashing 1 long, 4 short (TCL light) - any ideas?
With the A/T wire- ECU i would assume this is just a failure of the wire itself, which will be a simple case of checking it/fixing it up to connect properly?
Has anyone else come across this one before?
Error code 61 - A/T ecu
Re: Error code 61 - A/T ecu
Copied this from engine workshop manual......
You can look up connection numbers in the electrical manual
Cheers phil,
Yea almost as soon as i wrote this post i thought hey maybe its in the manual of exactly what to expect to do.
Matt has his workshop manuals printed out here in binders too - was just curious if this was a problem seen before or not and the best way to tackle it.
The TCL light as i said came on as well - so im thinking it may be a TCL ECU malfunction (the harness and the ECU seem fine from initial inspection doesnt look like its a cable fault) Would this throw it into limp mode?
Does anyone have a TCL ECU i could borrow for an hour to check if that is the problem?
- payaya
Think code 61 relates more to your TCU being stuffed.
