gear box n computer
- Taiwo
gear box n computer
Am not sure what is wrong with my car. The car is only driving in gear 3 n it wont gear down or gear up. It doesn't work in tiptronic either. I have changed the gear box oil but Notting happened.
Mitsubishi motors had no idea what it is but still charged me $90 for Notting. Dicks
Re: gear box n computer
Limp mode? If so change your input/output sensors?
- Dras
If you have tried everything else, I have a computer for the auto box that you can try if you want. It is for a 4 speed.
- Taiwo
Am going to try n change the output n input sensor. If that doesn't work I will grab that computer from u dras
Make sure you find out if you need 3 pin or 4 pin sensors before you buy.....
- Dras
- Taiwo
Mitsubishi said the error code 60
- Dras
I would suggest trying the method described in my previous post to confirm that. 60 doesn't sound right.
- Taiwo
i need a 4 pin input and output sensor 80% sure that is the problem where do i get one?
- Kustom
Yeah that's wrong error code. Get matt to show you how to get the real code
Well King Hit Kiz is complaining about my sensors and that he doesnt need them and wants a full refund so ill have a set of 4 pin mivec sensors available if you wanna give em a shot?
- Taiwo
Yea man. I will give it a try n see if it is them.
- Kustom
gear box n computer
It's probably more so the fact they weren't the problem in the first place..
- phi-tec
gear box n computer
mivec sensors? Correct me if im wrong but I recall Taiwos being non mivec?Taz wrote:Well King Hit Kiz is complaining about my sensors and that he doesnt need them and wants a full refund so ill have a set of 4 pin mivec sensors available if you wanna give em a shot?
- Taiwo
Haha I will correct u phi. My car is mivec.
Taz can i grab that 4 pin input sensor from u and i need a 3 pin output sensor.
is the input sensor the one under the battery?
Well King still has them and i havent heard from him in a while so i dunno whats the go, maybe he needed them after all
- Taiwo
so are the sensors usually a mix cause i think i need a 4 pin input and a 3 pin input sensor?
No, they should both be a 4 pin input and output - are you sure one is a 3?
- Taiwo
Well the output One is 3pin but not sure on the input. I will take a picture tomorrow
you have mivec but only a 3pin sensor
Interested to see how this one turns out
