I need some help :( (Facelift Indicators)(Cigarette lighter)
I've got those facelift clear indicators from the UK and im just wondering how to do i connect them up (wires)?
Its got like a plug connection on it. :(
Also would someone be able to tell me which wires plug into the cigarette lighter :lol:
Connor_1994
Re: I need some help :( (Facelift Indicators)(Cigarette ligh
Post by Connor_1994 »
As for the cigarette lighter
Where the wires for your head unit are, lower down the loom there should be two wires ( i believe one is is green possibly with a white stripe) and there will also be the lighter illumitor bulb next to them,
If that helps
If by tomirrow u havnt got it sorted ill pull mine apart, break it some more and send u a photo lol
As for the fog lights, do tou want them to run off you existing fog lights, existing parkers, or have them wired up seperatly on theyre own?
    dstocks wrote:This is what you are looking for:
    viewtopic.php?f=1&t=22270&p=257208&hili ... rs#p257208
    :cheers:
    illmotion
    Post by illmotion »
    I had same problem as you with my cigarette lighter last time as well until i started plug stuff in random place and got it to work properly, here a photo i took in case someone needed it.
