Swap: Facelift headlights
Just wondering if anyone would want to swap their facelift headlights for my perfect condition pre facelift?
- Shhtuart
Re: Swap: Facelift headlights
Lol why would anyone want to do that?
A wreck would be your best bet.
Lol there might of been a retard or something, it was a long shot.
+1 AgreesilverGPX wrote:Lol I might be a retard or something.
- Andym
whats the difference?
- Kustom
Parker is inside headlightAndym wrote:whats the difference?
Are'nt they factory fitted HID as well?Kustom wrote:Parker is inside headlightAndym wrote:whats the difference?
- Shhtuart
Only the GP Version R had the HIDs I believe.PHIL069 wrote:Are'nt they factory fitted HID as well?Kustom wrote:Parker is inside headlightAndym wrote:whats the difference?
which most of them would of been ripped out on compliance here tooShhtuart wrote:Only the GP Version R had the HIDs I believe.PHIL069 wrote:Are'nt they factory fitted HID as well?Kustom wrote:Parker is inside headlightAndym wrote:whats the difference?
- rock_it
HID was an option.. My facelift has them..
Yes, Version R had them factory fitted and they were an option on all other models.rock_it wrote:Shhtuart wrote:Only the GP Version R had the HIDs I believe.PHIL069 wrote:Are'nt they factory fitted HID as well?Kustom wrote:Parker is inside headlightAndym wrote:whats the difference?
- Kustom
Option only on facelift models I thought
That's what I meant. Was an option for all other facelift models.
Could i possibly drill a hole in the position in my prefacelift for the parker bulbs?
- Kustom
Yeah I would say you could. You'd need to make up a holder to hold the bulb in place though. Unless just cabletie it in.silverGPX wrote:Could i possibly drill a hole in the position in my prefacelift for the parker bulbs?
If you buy the proper fitting, then dremeled the shape correctly, then there should be zero issues.
Cable tie
seriously Kustom....
Cable tie
Fking LOL
- phunkydude
Instead of mucking around on the headlights..,
why not get a pair of foglights to fill up the hole on your facelift bar and wire it to the parker switch, change the bulb to white led.
Wanna source me some foglights then andrew
- Kustom
I'm an electrician. I'm allowed to use cable ties everywhere !Astron_Boy wrote:If you buy the proper fitting, then dremeled the shape correctly, then there should be zero issues.
Cable tieseriously Kustom....
