Wheel hub noise
- ZFL45H1
Wheel hub noise
Guys my problem ATM is I have wheel hub noise only in the back as I rebuilt the fronts no long ago so this Is what I have done my spare Fto by looks feel and sound had new rear hubs on it so I changed them over to my fto and was good until on my way back from qld last weekend and the noise from them was worse then my old ones where only installed for 3 days
A few queries I have are
1: because the new hubs didn't get used in say over a year would they seize up or
2: could it be the possibility of my rear pads being a little sticky
Cheers
Cheers
Re: Wheel hub noise
http://www.ebay.com.au/itm/MITSUBISHI-F ... 577wt_1163
Lemmie guess, your car has done 1xx,xxx odd kms? Your wreck similar? Just buy new ones.
- ZFL45H1
Wheel hub noise
Fair enough shall do is my rear pad being sticky possible at all
Re: Wheel hub noise
Maaaaybe, unlikely though. To do properly, you have to release the tension on the handbrake cable from under the cup holder inside, then wind the calipers back into place using needle nose plyers.ZFL45H1 wrote:Fair enough shall do is my rear pad being sticky possible at all
You can check the hubs though, just spin them quickly in your hand. Listen for noise.
- ZFL45H1
- payaya
Re: Wheel hub noise
Good test is if you believe your hand brake is dragging, while its humming away pull the hand brake with your thumb always on the button and give it a couple of small yanks. If it changes noise it could be your hand brake dragging, but a dragging hand brake usually does not make any noise.
Im over 200k and rear bearings are fine.
Usually sealed hubs give out more noise when your tyres are sort of flat. Try pump them up to 40psi and see if the noise reduce are goes away.
- ZFL45H1
Wheel hub noise
Bennoz I tried to get rear wheel bearings but have been told its not possible as it is a single unit and I have to by the whole hub they told me to go to Mitsubishi to get them or should I go on eBay and try that way what u think
Cheers
Cheers
Re: Wheel hub noise
http://www.ebay.com.au/itm/MITSUBISHI-F ... 53e6c16d31
EDIT: Whoops these are for ABS models....but email them and ask for your ones
- ZFL45H1
- ZFL45H1
Wheel hub noise
Anyone know the part number for these bad boys
Aka rear wheel hub assembly cheers
- ZFL45H1
