Can U help me make my GR faster?
joshfto
Post by joshfto »
Anyone here with a GR that has done some modifications, what have you done, and what are some of the easiest and less expensive mods.
Boris
Post by Boris »
I don't have a GR, but these things are mostly the same between cars.
The first two things I would consider is a CAI and an Exhaust.
dl_archangel
Post by dl_archangel »
I was browsing on the UAS website, and came across the FTO Cold Air RAM Pod Kit $295 for GR's, which includes pod filter. Just curious at how much extra power this would add?
Boris
Post by Boris »
It's not as much important "how much power" but more of how it will improve your power curve & torque curve I believe...
I think at the last FTO Dyno day, a CAI was fitted to a stock car and it produced i think this:
GPX Manuals
TJ2709 99.6 (went up to 105.1 with the CAI fitted)
from this thread:
http://www.ftoaustralia.com/modules.php ... 8&start=40
Keep in mind that that is for a GPX though, but you should see similar results. Apart from improving the power, the CAI will also give you a better torque curve...
