Hi I'm Linda just bought an FTO today... Headlights and tail lights are in bad shape where can I get a set if crystal headlights!!! So so wanting some, thanks xo
Hi Linda WTTC ,
I don't think that you can get "crystal headlights" for the FTO. Most of us have had to sand and polish our headlights to clean them up, if you do a forum search for "headlights" you will find a lot of info. You can find some new or pretty good headlights on eBay some times, but they are very expensive.
Read through this...... http://ftoaustralia.com/v3/viewtopic.ph ... ts+sanding
BTW,
Which FTO do you have?
Colour?
Any mods?
Which state ru in?
Ah it's black and the owners name was Kate... And yeah the back lights were snapped on the corners, I want to fix all the little blemishes so u know a lot about this car then, i had it towed to my mechanic this afternoon to fix water pump change timing belt and give it a major service. I'm hoping that's the only engine issues with it.
Changing the gear box oil.
Finding out what the clunk is inside the passenger door.
Also their is a whole wiring kit i left in their installed for a sub and amp in the boot itll be tucked in under the boot floor. Amp and sub will hook straight up.
Machining the discs.
Replacing the Oxygen Sensor & Engine Temp Sensor.
Ok cool, any idea where I'd get the pieces to fix the sunroof?? I'm having the roof retrimmed next week and would like to do it while the linings off... Also u know the ugly rubber on the top of the doors? What can I do about that? Thanks for your help
Rad FTO wrote:Ok cool, any idea where I'd get the pieces to fix the sunroof?? I'm having the roof retrimmed next week and would like to do it while the linings off... Also you know the ugly rubber on the top of the doors? What can I do about that? Thanks for your help
Their the weather strips and i would highly recommend not taking them off as i have sikaflexed them on and it sets like concrete and you'll be left with a mess behind. Just spray them with Black Plastic Bumper paint.
Why are you getting the roof retrimmed?
To fix the sunroof hmmm, not sure youll have to ask around for that.
