Tip Radiator Hoses
Tip Radiator Hoses
New radiator hoses arrived today thanks to dstocks :D :cheers:
Couple of things - Im wanting to paint them blue, would simply spraying on some engine enamel work?
Also, with fitment, is it as simple as it looks? e.g. Just undoing the clamps and swapping them, or do I need to do anything else first?
Cheers.
Tip Radiator Hoses
You need to take out your tail lights to get access to install them :troll:
Yes, just clamps hold them on may have to cut the old ones off depending how fucked they are
And I wouldn't spray them lol
Re: Tip Radiator Hoses
If you want blue hoses, then buy Samcos'.
You don't paint rubber.
Astron_Boy wrote:If you want blue hoses, then buy Samcos'.
That's not the only option, you can wrap them in Silicone Rescue Tape as Dwayne and I have done with the UAS pipe.
That's true, but given the amount of extra heat on the rad pipes, would that be suffice?
I would assume so, as that is one of it's intended uses (sealing a damaged hose) and is able to withstand temperatures of up to 260 degrees.
Fair enough.
If your hoses are stuck on, giving them a rotational twist can help crack them off the radiator :D
If you can't get the new ones on, boiling hot water from the kettle poured onto the ends of the hoses will soften them giving an easier fitment :D
Ok cool. Is there anything I should remove first? Like the pipe from the coolant reservoir or something? Or will I just have to drain the whole thing?
In regards to samcos - That was the plan but I simply dont have the money for them right now, especially considering they arent necessary at the moment. Dont wanna pay double the price for a colour :lol: :roll:
When you take the bottom radiator hose off it will all drain out anyway.
If you want to flush the "coolant bottle" just stick the garden hose in it and turn the tap on full.
Stick the garden hose in the top of the radiator too, when you have both hoses off, it will flush it out.
When it's back together and you have filled with new coolant, run the engine with the radiator cap off and top up as required until no more bubbles come up and the cooling fans start spinning, put cap on and drive, recheck levels after cooling down.
Tip Radiator Hoses
Or take the hoses off it and pull it out... It's just wedged in there
As for draining, there is a butterfly plastic screw on the bottom ofthe radiator. Just undo that
Sahin wrote:As for draining, there is a butterfly plastic screw on the bottom ofthe radiator. Just undo that
If you are going to reuse the old coolant, which I wouldn't, or want to drain into a bucket then the butterfly is the right option.
If you are just going to drain onto the lawn then bottom hose will drain quicker :D
Tip Radiator Hoses
And get sh*t all over your hands :(
:cry: poor boy :cry:
Play hard :lol:
Okay cool, cheers
Sahin wrote:And get sh*t all over your hands :(
I got some concrete gloves that will see to that.
Tip Radiator Hoses
I knew I'd get sh*t for that lol
