Fuel filter
Kablaamo
Fuel filter
Post by Kablaamo »
Ok... was looking through the fuel filter wall of shame becuase i was bored then i was thought to myself.. holy sh*t when was mine last changed i never have i hope it was changed on a major service i had done but to be honest i have no idea..
How do i do this? :D
Re: Fuel filter
If you look on page 2 of the wall of shame, I posted instructions on how to do it.
viewtopic.php?p=297840#p297840
Vectose wrote:Not overly difficult. Took me 30 minutes to replace mine.
You will need:
14mm Flare Nut Spanner for the bottom flare nut
19mm Spanner for the top bolt
12mm Spanner or socket
10mm Spanner or socket
Step 1. Remove the bottom rear seat cushion, and you will see a plate in the centre held on by four screws. Remove these four screws and then disconnect the connector from the fuel pump. Start the engine and allow it to stall on its own.
Step 2. Remove the intake pipe and battery to gain better access to the fuel filter.
Step 3. Undo the bottom flare nut using a 14mm flare nut spanner. (I did this from under the car but it is possible to do it from above.
Step 4. Undo the top eyebolt using a 19mm spanner.
Step 5. Remove the two 12mm bolts holding the bracket to the firewall.
Step 6. Remove the old filter and bracket from the car and loosen the 10mm bolt that holds the fuel filter in the bracket, Put the new filter into the bracket and tighten up the bolt.
Step 7. Put the new filter and bracket back into the car and tighten up the two 12mm bolts.
Step 8. Tighten up the bottom nut with the 14mm flare nut spanner.
Step 9. Place the two new copper washers you should have received with your new filter onto both sides of the eyebolt and then tighten it up to the filter using the 19mm spanner.
Step 10. Reconnect the fuel pump, intake pipe and battery then start the car and check for leaks.
Kablaamo
Re: Fuel filter
Post by Kablaamo »
Ah i was just scrolling to see photos XD didnt read anything, cheers mate! im assuming i can pick up a fuel filter from repco or something of the nature?
Re: Fuel filter
Kablaamo wrote:Ah i was just scrolling to see photos XD didnt read anything, cheers mate! im assuming i can pick up a fuel filter from repco or something of the nature?
Yep, part number is Z441.
Re: Fuel filter
If you want kablaamo we can change ours together at mine, ive done a fair few now. Mine needs doing again.
Kablaamo
Re: Fuel filter
Post by Kablaamo »
silverGPX wrote:If you want kablaamo we can change ours together at mine, ive done a fair few now. Mine needs doing again.
That would be fairly hectic... whens good for you? (cant do this weekend)
Re: Fuel filter
Fairly hectic? Lol it takes 20mins.
Ive got a sparkplug tool if u want to change the sparkies too.
Fuel filter
I'll grab you for a day to do sparks aswell
Getting my mechanic to do fuel filter while he's fixing my oil leak... (cam seals or something :shudders:)
Kablaamo
Re: Fuel filter
Post by Kablaamo »
Done deal, what sparkies do i need.... :D costly?
Fuel filter
That was my next question...
Re: Fuel filter
Ill be back with an answer later tonight.
Kablaamo
Re: Fuel filter
Post by Kablaamo »
Roger that
Fuel filter
Join us after these news headlines
Re: Fuel filter
Sahin wrote:Join us after these news headlines
Good evening,
There has been a recent spate of FTO accidents this last couple of months. The poor little cars just seem to be in the wrong places at the wrong times. The majority of the smashed FTO's are being written off by insurance companies. This is causing quite an uproar within FTO circles, on one hand they are becoming slowly rarer but on the other hand the insurance premiums will surely start to climb in the near future. We attempted to interview the National FTO President but he had no comment. We hope this bad luck is at its end and that the FTO community can live in peace.
Kablaamo
Re: Fuel filter
Post by Kablaamo »
Pure quality
That is some talent..
Though sad about all the FTO crashes lately :(
