Production Figures
Production Figures
I thought it was time to drag this information out again. Below are the production figures for the FTO according the CAPS (Mitsubishis Parts database). CAPS has every chassis number for every FTO made and for each it specifies information such as model, colour etc. A few years ago, I reverse engineered the CAPS database to get at the data and below are some of the results:
Model Numbers Produced Each Year
Code: Select all
Model           1994 1995  1996 1997 1998 1999 2000 Totals
GS              817  2586  380  206  112  80   20   4201
GR              5423 6726  158  66   37   19   4    12433
GR Limited      0    1602  0    0    0    0    0    1602
GR Sport        0    2     1807 0    0    0    0    1809
GX Sport        0    0     0    768  307  199  69   1343
GX Aero         0    0     0    19   144  73   59   295
GPX             2992 8505  1267 566  237  155  81   13803
GPX Nakaya Tune 0    0     122  0    0    0    0    122
GPX Limited     0    207   0    0    0    0    0    207
GP              0    1     77   0    0    0    0    78
GPvR            0    0     0    353  102  65   22   542
GPvR Aero       0    0     0    16   199  99   56   370
Totals          9232 19629 3811 1994 1138 690  311  36805
So, lets look at this. If we take my 99 Aero as an example, yes its a limited edition Version R, but it is actually less rare in 99 than the standard version R with 99 made vs 65 standard models made. There are other interesting figures in here as well. So, in short, before saying you have something very rare, do your homework, because it may not be as rare as you think.
Here is the same thing with colours:
Model Numbers for each Paint Colour
Code: Select all
Model           Pyrenees Steel  Icecelle Passion Scotia  Dandelion Moonlight Symphonic Timber Kielder Imperial Kutani Unknown Totals
                Black    Silver Blue     Red     White   Yellow    Blue      Silver    Green  Green   Red      Red
GS              841      1592   19       532     393     0         348       140       1      3       326      1      5       4201
GR              2872     5291   7        1680    835     0         826       39        1      2       874      0      6       12433
GR Limited      554      690    0        357     0       0         0         0         0      0       0        0      1       1602
GR Sport        395      587    0        189     346     0         187       0         0      0       105      0      0       1809
GX Sport        252      0      61       147     455     0         0         415       3      5       0        0      5       1343
GX Aero         55       0      6        46      124     0         0         63        1      0       0        0      0       295
GPX             3533     4707   56       1839    1778    1         807       245       8      4       808      0      17      13803
GPX Nakaya Tune 0        0      62       0       60      0         0         0         0      0       0        0      0       122
GPX Limited     0        0      0        0       0       207       0         0         0      0       0        0      0       207
GP              11       17     0        5       30      0         12        0         0      0       1        0      2       78
GPvR            91       0      0        48      402     0         0         0         0      0       0        0      1       542
GPvR Aero       46       0      0        38      284     0         0         0         0      0       0        0      2       370
Totals          8650     12884  211      4881    4707    208       2180      902       14     14      2114     1      39      36805
I have done some preliminary cross checking against VIN numbers in CAPS and all figures seem to match up which means that there is a reasonable chance that these figures are correct. I dont know where the production figures on some of the websites out there come from, but without a reliable source id have to say that it is most likely that they are flawed.
Not exactly what I would have expected, but there you go. Wouldnt mind a Kielder Green or Timber Green one. Have seen a picture, but with only 14 ever made, would be extremely unlikely to pick one up.
Maybe I should also do one based on transmission. You quite often see people advertising their manual as a 'rare' entity as well.
    phi-tec
    Re: Production Figures
    Post by phi-tec »
    :cheers: my 94 gpx is more rare then the 95 gpx! *adds a few hundred to sale price
    jks
    i saw like a basic version of this on wiki, pretty interesting :D
    Is there a code to tell if its rare to have a gpx with an uprated brakebooster?
    I wonder what the unknown colours are :?:
    It would be interesting to see how many of each colour where made each year, and then what transmissions as well, I know in my copy of the Mitsi ASA, it can tell me what Transmission I have, so It should be possible to get that in mass numbers like that shouldn't it?
    phunkydude
    Post by phunkydude »
    So, GX isn't the replacement of GR ? aka pre-facelift to facelift 6a12 non-mivec fto
    Yes, is possible. Ill put it on the list of things to do.... ;)
      So my 1998 GPvR is more "rare" than a 1998 GPvR Aero? :scratch:
      Carsales.com.au
      "This is a fully sick rare GPvR only 102 made in the WORLD in 1998"
      :cheers:
      Only 48 red Version R's. :cheeky:
      Interesting there are more silver and black FTOs, but I always tend to see white.
      Cousin
      Post by Cousin »
      super rare black gpx 1998 :thumright:
      Super common passion red GR 8)
      Bennoz wrote:Super common passion red GR 8)
      there is nothing common about your car Ben :twisted: .
      And all the common bits have been replaced.....
        -Nighthawk-
        Post by -Nighthawk- »
        What method are using to get a full list of vehicles dstocks? I have the software installed just unsure how to use it properly. So far I can only look up the part numbers of the car etc.
        You wont be able to get the tables I have put up. You can enter your chassis number and itll give you a bit about your car or select parts, but thats about it. .
        I managed to decrypt the database tables and wrote some code to extract the data into Microsoft Access. I havent managed to get everything out, but have enough.
          I just checked and have a text file with all the data in it. Is 2.3mb. Happy to email it to anyone that wants to have a play with it. Is a CSV file, so should be able to suck it into most databases without an issue.
            What is the Nakaya tune?
            phi-tec
            Post by phi-tec »
            spetz wrote:What is the Nakaya tune?
            wouldn't that be coty?
            phi-tec
            Post by phi-tec »
            nvm ignore me im retarded
