Turbo Timer
Turbo Timer
as iam gettign a new engine in and having experianced the cst of such a thing :9 i am fittign a trubo timer to be that extra bit safe with my engine....
i was woundering what would people recomend? i want a ice Razo one but there ultra rare etc...
my bro thanks one like in his s15, a pencile A'pexi, is pretty good, but half the options you pay for on it are purly turbo options....
i was woundering if anyone could recomend a good 2 in 1? (turbo and speed timer)
- GPXXX
- FTO338
Hmmm I had a turbo time on both N/A & turbo car before, & its useless in N/A car, the only thing it will do its actually build up the heat in the engine, so you not actually saving your engine.
Is just like when you idle the car for awhile at the red light, you can see the engine temperature raise up & the thermal fan turn on just to cool down the engine.
The whole idea of turbo timer is for the heat/pressure that you had build up during driving to escape, as turbo produce 4 times the heat compare to same engine that is N/A.
well i am after any safty mesure after poping out the money for an engine etc...
and from what i have read its equally importent to cool the engiens internals as it is to the turbo?
think i solved the problem though
ebay - tway fm alarm with remote engine start for cold mornings(climate controll
and turbo timer
I'm with Kev and Mikey on this, it really won't offer any advantage to a NA engine, the heat just isn't that big an issue. But you seem hell-bent on getting this thing which makes me think you want it for reasons other than cooling your engine down, so it really doesn't matter what we think ![Razz :P](./images/smilies/icon_razz.gif)
MIVEC is My Friend :D
- Slither
ive always let my engine idle for at least 20 30 sec's after a Hardish' run..
my theory is that the Coolant still runs around the engine whilst running thus a mild cooling effect. but after a certain period of time the coolant gets hotter and so does the engine.. so leaving it on for a long time(3mins) wouldnt be a good idea.
My 3c
Jono
My 3c
Jono
- FTO338
Do keep in mind engine start is illegal for the manual cars in Australia, & unless the supplier give you a separate solenoid for the manual, it won't work either.
