Bens FTO GPX
benrad666
Bens FTO GPX
Well just brought my first FTO
$3000 off eBay black with some hail damage
very happy as I have wanted one a long time now. Goes in for roady next week
can't wait to be Rollin the streets in one of these! Im new here n this my first post, so bare with me I'm noob
Can't upload pics cause I'm on iPad?? so I'll have 2 do it later.
- kiz
- SA Coordinator
Re: Bens FTO GPX
WTTC
Post some pics soon for us to see
1998 Mitsubishi FTO GPVR AERO
benrad666
Re: Bens FTO GPX
got some pics up
all seems good,drives good pleanty of power
few things i have noticed though
- the revs tacho does not move
the exhaust waring light is on and the abs light
and when in drive and slowing down it wont select second, just goes from third to first. anyone know why?? second is fine when using sports mode.
now just hoping the roady goes good n ill be one happy fto driver!! will be needing some mags
might need a paint job sooner or later to as there is clear pealing on the roof,doors r faded, and some hail damage
Re: Bens FTO GPX
Apart from the obvious.
It's not bad for 3K.
Having said that, with that amount of hail damage, won't you have insurance issues?
Let alone rego
Good luck.
3rd to 1st is normal, that's the tip computer doing that.
Will need to fix that warning light meanwhile, and tacho for rego.
Let alone rego
Good luck.
- spetz
Re: Bens FTO GPX
Welcome to the club
- BUZZ_QWERTY
Re: Bens FTO GPX
Wttc! Don't worry, it's completely normal... Fto's do a few weird things like that, your gonna notice that if you go down a hill with your foot off the accelerator its gonna change into second to try and slow things down.benrad666 wrote:when in drive and slowing down it wont select second, just goes from third to first. anyone know why??:(
- kiz
- SA Coordinator
Re: Bens FTO GPX
That's why real men drive manualsBUZZ_QWERTY wrote:Wttc! Don't worry, it's completely normal... Fto's do a few weird things like that, your gonna notice that if you go down a hill with your foot off the accelerator its gonna change into second to try and slow things down.benrad666 wrote:when in drive and slowing down it wont select second, just goes from third to first. anyone know why??:(
- Supplanter
Re: Bens FTO GPX
And then bitch about it very time they drive in peak hour traffic.kiz wrote:That's why real men drive manualsBUZZ_QWERTY wrote:Wttc! Don't worry, it's completely normal... Fto's do a few weird things like that, your gonna notice that if you go down a hill with your foot off the accelerator its gonna change into second to try and slow things down.benrad666 wrote:when in drive and slowing down it wont select second, just goes from third to first. anyone know why??:(
- kiz
- SA Coordinator
Re: Bens FTO GPX
ToucheSupplanter wrote:And then bitch about it very time they drive in peak hour traffic.kiz wrote:That's why real men drive manualsBUZZ_QWERTY wrote:Wttc! Don't worry, it's completely normal... Fto's do a few weird things like that, your gonna notice that if you go down a hill with your foot off the accelerator its gonna change into second to try and slow things down.benrad666 wrote:when in drive and slowing down it wont select second, just goes from third to first. anyone know why??:(
- BUZZ_QWERTY
Re: Bens FTO GPX
benrad666
Re: Bens FTO GPX
Got the roady,, not to bad I must say
here's a list-
Polish front lights (give this a try tomorrow)
Whiper blades
Centre brake light (was just globes)
O2 sensor to be connected under car (plug was missing I just cut n rejoined the wires)
Front abs line cut driver side,,strange why would someone cut this?? ( joined bac up)
Front bumper,, piece under number plate is missing!!
Anyone have a VS front bottom lip for sale Melbourne western suburbs??
D/s drive shaft boot, is this hard to be done?
Front and rear brake pads
Front and rear engine mount
P/s steering rack boot,,is this hard?
So not to bad!! Will maybe just get a mechanic to do the rubber boots and the engine mounts.
Can't wait to be on the road
O and a another question if I reset the computer (disconnect battery for 15 mins?) and then drive with sports shift for a week,, will the computer learn my driving style?? Or does it only learn when in drive, not sports mode?
And thanks for the help, glad to have a FTO and be aprt of the club
Whiper blades
Re: Bens FTO GPX
Engine mounts arent that hard and it seems you have some confidence in doing some mechanical work - theres a good DIY guide here and Ben/Dwayne can source some cheap mounts for you im pretty sure.
Every mechanic will charge you a little bit extra for boots as they are the least favourite job to do on a car for most.
Wiper blades are like 10 bucks, globes will be what 5 bucks. Brakes (brand and level dependant) wont be TOO much all in all not bad, does it have any roof rust? Thats the most common expensive problem it seems.
Cant tell you 100% about the tip but id assume it would learn everything you do.
Im sure it wont be much to fiberglass up the bumper? depending on the damage might be cheaper than buying a new one.
WTTC too btw
WTTC too btw
- AJ
Re: Bens FTO GPX
I had both replaced by a mechanic and he only charged $90 to supply and fit both sides so it can't be that hard.benrad666 wrote: D/s drive shaft boot, is this hard to be done?
Only in D. You have full control in sport shift mode.benrad666 wrote:O and a another question if I reset the computer (disconnect battery for 15 mins?) and then drive with sports shift for a week,, will the computer learn my driving style?? Or does it only learn when in drive, not sports mode?
- iPilot
Re: Bens FTO GPX
When u guys talk about the sports mode do u mean driving in the tip or is there a physical button or something that engages this sports mode?
From what i can see my gpx doesnt have any sports button of any sort.
Its either an FTO or nothing!
Re: Bens FTO GPX
I believe it's just in Tip
- AJ
Re: Bens FTO GPX
^ thisTechnikhaus wrote:I believe it's just in Tip
benrad666
Re: Bens FTO GPX
Can't find any engine mounts in stock
And can't be ordered today because it needs to come from Mitsubishi
Is there any other models mitsu that have same engine mounts?? Maybe can be ordered today! And maybe will even be cheaper
benrad666
Re: Bens FTO GPX
Yes it does have some rust in the roof but it seems only minorTaz wrote:does it have any roof rust? Thats the most common expensive problem it seems.
And thanks for the info guys!!
Bens FTO GPX
$1000benrad666 wrote:Yes it does have some rust in the roof but it seems only minorTaz wrote:does it have any roof rust? Thats the most common expensive problem it seems.It's like bubbles in under the paint the paint has not chipped away.Was told it's easy to fix?? Hope it's not 2 costly
Re: Bens FTO GPX
The below parts are the inserts needed, take these to a mechanic and tell him you want these inserts in your engine mount brackets.benrad666 wrote:Can't find any engine mounts in stockAnd can't be ordered today because it needs to come from Mitsubishi
Is there any other models mitsu that have same engine mounts?? Maybe can be ordered today! And maybe will even be cheaper??
He'll remove the cross member, punch out the old dead rubbers and put in the new ones you gave him and reinstall the cross member.
job done.
