So I've decided that I miss you guys (well, some of you), and will be trying to get to more events, whether that be risking my life in Lawso's car, or towing bennoz's back from Wakefield
So, here's what's fitted to the car so far:
Safari Snorkel
BFGoodrich All Terrain's (LT265/70R17):
GME TX3100 UHF with a 6.5dB Antenna:
Ultimate Suspension 2" Lift Kit with Red Braided Brake Lines:
ML Styleside (about 25cm shorter than the one I had) and MCC Rear Protection Bar:
Provent 200 PCV Separator (these things get phenomenal blow-by when running 26psi boost):
Galvanised 4mm Steel Bash Plates (already been given a workout):
Chip-It Diesel Performance Chip with Exhaust Gas Temperature Controller, running Tune 8. Currently running 26psi (30psi spikes from VGT) and probably pushing about 200hp (150kW) and around 550Nm at the flywheel (stock is 175bhp (131kW) and 400Nm). Running a UniFilter (prefer it to K&N as it filters dust out better) and yet to get an exhaust to make the most of it
Uniquely shaped sidesteps, to be replaced with either Bushskinz 4x4 or AVA Rocksliders.
Custom Pin-striping and dents.
Narva Ultima 175 75W Halogen Driving Lights and HID 6000K 35W Hi/Lo headlights.
Full sound system upgrade utilising the factory MMCS GPS Head-Unit, albeit modified to gain more bass output. Kenwood 500W 4ch amp powering 4 Alpine SPS-600 3way door speakers. Factory tweeters running of the standard sound unit, don't really need to amp them. Have been looking into a slimline sub/amp combo, but will have to wait and see how funds go as I want some muddies first
