Buying fto manual gpx radatior
- renzkuken1
- aza013
- NSW Coordinator
- renzkuken1
Re: Buying fto manual gpx radatior
Yeah i noticed, would i be better of getting mine cleaned or buying a new one? Is the auto one different to manual gpx?
- aza013
- NSW Coordinator
I think it's just the pipes that are different, but I could be wrong
- renzkuken1
well i have no idea haha, if it was auto but converting to manual would pipes be the same as the auto or will i need to get manual radiator. Anyone in the know would be great. Cheers.
- aza013
- NSW Coordinator
I think it's the lower pipe that is different on the auto box setup but the top ones are the same. I'm testing the memory now so again could be wrong
Quite right, lower hose has a bend in it to avoid the clutch slave. You can use an auto hose, but you need cable tie it out of the way.
And you just cap off the oil pipes as the manual doesnt need them
