The tachometer in my gpx just stays on 0 and does not move. I know this is a common problem with fto's and have heard the the fuse is usually the problem. Can I just replace it from the fuse box or does the dash need to be removed. Anyone know if i can reset/reboot it to get it working again? any ideas?
Thanks Gaby
Tachometer not working???
- gabs
Re: Tachometer not working???
Ignition failure sensor, talk to dstocks it's quite a cheap fix
- the real technikhaus
Possibly the IFS... I don't believe the tacho has it's own fuse, instead its one that covers all (most) of the instrument cluster. So basically the IFS is your best bet.
Yep, most of the time its the Ignition Failure Sensor.
