Jap import vs Australian specs
- gabs
MY knowledge is that an fto imported from japan (Jap specs) is better than an fto with australian specs. Although i have been told that with certain cars such as rx7 australian specs are preferred over jap imports. Any thoughts?
Re: Jap import vs Australian specs
There is no 'Australian spec' FTO as far as im aware, it was never dealer delivered in Australia, you had to pretty much import one yourself back in the day which was pretty tricky.
The only thing i can think of what Aus spec could be is when it is imported it has to be stock standard, however again this wouldnt change anything to an 'Aus spec'
Perhaps clarify a little more if i am missing the point here, otherwise the answer is nothing, as there is no 'Aus spec'
Hope that helps
Hope that helps
- Eltnot
Yep, All FTO's are Grey Imports in Australia.
- bass_twitch
- Kustom
- SchumieFan
To throw a spanner in here, the Aus FTO weighs more.
10points to whoever figures this one out.
- Eltnot
Because they don't have skinny Japanese guys driving them anymore?Astron_Boy wrote:To throw a spanner in here, the Aus FTO weighs more.
- SchumieFan
ROR...Eltnot wrote:Because they don't have skinny Japanese guys driving them anymore?Astron_Boy wrote:To throw a spanner in here, the Aus FTO weighs more.
because of the child seat anchors that get fitted on compliance... and the dimmer
on the right track, but no donutSchumieFan wrote:ROR...Eltnot wrote:Because they don't have skinny Japanese guys driving them anymore?Astron_Boy wrote:To throw a spanner in here, the Aus FTO weighs more.
And sorry Elt, but no, I weigh as much as a skinny Japanese guy, lol
As does schumie. ROR
- aza013
- NSW Coordinator
If you read between the lines of what astronboy has said there are some hints there
Because Aus spec ones have kegs in them
- payaya
Aren't bars welded into the door for compliance?
- aza013
- NSW Coordinator
that there is a winBennoz wrote:Because Aus spec ones have kegs in them![]()
extremely, lolaza013 wrote:that there is a winBennoz wrote:Because Aus spec ones have kegs in them![]()
indeed they do! 10 points.payaya wrote:Aren't bars welded into the door for compliance?
- Eltnot
Crap, mine doesn't have that upgrade. Where can I get it installed? At the bonfire?Bennoz wrote:Because Aus spec ones have kegs in them
Hmm, any chance fitting a wine barrel if we were to remove the rear seat?Eltnot wrote:Crap, mine doesn't have that upgrade. Where can I get it installed? At the bonfire?Bennoz wrote:Because Aus spec ones have kegs in them
Hmm I wonder if NZ has that?
- gabs
ok fair enough guys thanks
