Again, just advertising some of the work i am able to do - this time with a few more piccies as ive done it to my own car.
I can do custom boot setups like mine pictured and many more styles - pretty much any setup i would tackle.
I just purchased a second amp so i will be completely changing mine so i will have another one to show off soon which will be done properly (my current one i am not satisfied with the quality(i half assed it and didnt bother to tuck the carpet underneath the mdf so you can see it - that is a makeshift one to test that setup so you can imagine what a fully finished quality setup would look like)
Also, Matt can do complete car re-wirings of all subs/amps/capacitors/speakers etc on a very professional level (probably better actually with todays lazy auto lekky's) for dirt cheap too
So between us we can completely setup install and wire in a quality custom setup specific to your needs at a fraction of what somewhere like JB or WoW would charge you (they tried to charge me 170 to install two front speakers lmao! 4 wires and 8 screws in total, possibly 10min work)
Also between my custom interiors and Matts ability to do most minor work on cars, basically anything your FTO needs in Brissy we can suss out, take it from rags to custom goodness with a good service and tune up as well. (And with Dwayne supplying virtually every part of the sun - why go to anyone outside the club (and how many car clubs could be completely independant no matter what it is?
Back on topic - again prices will vary depending on what you want done - i know Matt is looking around the 100-150 dollar mark for a complete rewiring (trust me you will not get anywhere near this low anywhere for a full days work minimum) and i think minus whatever the materials will cost for what you want i will charge around the same depending on how complicated you want things, if you want a custom sub box as well etc etc.
Something like mine (pictured) will set you back about 75 as it is done with the stock boot insert, carpet and very simple design underneath - however something like what i will do next
(complete under carpet, 2 see through perspex sheets and a little trickier to do) will be about 125, 150 for a custom sub box as well etc to give you an idea of price
I will probably charge that little less if you want a custom interior done as well at the same time.
In any case let us know what you want and ill suss it out and get some design ideas drawn up etc
Cheers
