Stock Exhaust?
Stock Exhaust?
Cant tell if my exhaust is stock or not, it definitely sounds like it isnt however I can't be sure. Tried searching online and cant find much. Does anyone have a picture of a stock FTO exhaust?
Re: Stock Exhaust?
Twin tip. Just get a look at it if it looks old and corroded it'll be stock, judging by the car I've seem its most likely stock and if your still not sure if the twin tip OS stock look for a weld behind the tip. But its going to be stock, is 87db loud stock so easy mistake I guess
BearOnFire
Re: Stock Exhaust?
If you got around $80 to burn, have the main resonator(located at the mid section of the car) removed from a exhaust shop. LFA'ish
- payaya
Re: Stock Exhaust?
The stock muffler has Mitsubishi written on it. Mine stock is 89db!Taz wrote:Twin tip. Just get a look at it if it looks old and corroded it'll be stock, judging by the car I've seem its most likely stock and if your still not sure if the twin tip OS stock look for a weld behind the tip. But its going to be stock, is 87db loud stock so easy mistake I guess
- Cousin
Re: Stock Exhaust?
Yep that'd be it, cheers
