Anyone else felt their Fto Shaking?
Ftowner
Post by Ftowner »
Im just wondering if this is a common problem, or if its just my tyres or something else. Its usually when im going up a hill and im just slightly on the accellerator going around 40 - 60 km/h, after a while the car starts shaking and i have to either accellerate a bit more or take my foot off the accellerator and it stops shaking its very odd and doesnt happen that often but im wondering if anyone else gets this or if its just the weird tyres the dealer put on?
Playboy_FTO90
Re: Anyone else felt their Fto Shaking?
Post by Playboy_FTO90 »
Mine does this aswell...i have no idea what it may be though!
mosti
Post by mosti »
........ if it's a manual, try lowering your gear?..
Sounds like you're in the wrong gear and the car is struggling..
Agree ^^^^ or it could be your engine and or box mounts are gone/ on there way out.
Mounts....
    JOA81
    Post by JOA81 »
    Could it also be a misfire because the engine is under too much load with not enough spark my Celica had that kind of problem at low acceleration with high load I just had to replace the plugs
    I vibration under load if definitely your mounts and most likely your rear mount going soft.
    FTO-BOY
    Post by FTO-BOY »
    Buckled wheel? Mounts... Wheel bearings...
    FTO-BOY
    Post by FTO-BOY »
    Also sh*tty tyres :)
    FTO-BOY wrote:Also sh*tty tyres :)
    During accelerator pressed only!
    Ftowner
    Post by Ftowner »
    [quote][/quote] Its an automatic so it cant be a gear problem. Im hoping its the tyres but if it is the "mounts" what can i do to fix this? Or how can i diagnose it?
    mosti
    Post by mosti »
    Duno why nobody has responded to this....
    If it's the mounts they need to be replaced. As for a diagnosis, I guess you'd have a geez and to see of they're worn/damaged....
    Never replaced engine mounts before lol.
    BearOnFire
    Post by BearOnFire »
    Does the transmission fluid have a burn smell? If so best to have it checked out buy a specialist.
    If your car is a 95-98 and you have not changed your mounts there are stuffed. I don't need to see them and can guarantee they are stuffed.
    Generally the side mounts start to crack at the rear side of the mount and start to say. Once this happens your engine literally rests on your front and rear mounts causing them to sh*t themselves, which causes the vibration.
    Ftowner
    Post by Ftowner »
    payaya wrote:If your car is a 95-98 and you have not changed your mounts there are stuffed. I don't need to see them and can guarantee they are stuffed.
    Yeah its a 96, sounds like you know what is going on. Thanks for the replys guys im going to get it checked soon and hopefully replace them. Hope its not too costly!
    Even if you replace the rear mount it will still vibrate. Get a manual one or fill in the gaps of an auto mount and the vibration stops.
