Wheels spinning when not in gear
Eltnot
Post by Eltnot »
Started my car to warm it up a bit whilst it was on stands as I needed to tighten the sump plug as I've noticed a slight drip from it. When I push the clutch in, the wheels stop spinning but when I release it, both front wheels spin slowly even though the car is not in gear.
Clutch on its way out?
Other cause?
Also, Taz after searching the forums for a better place to jack the front of the car up, you sure use the work "jack" a lot.
Re: Wheels spinning when not in gear
That's quite normal. The primary shaft in the gearbox still rotated slowly when in neutral.
had the same thing with my Magna, car would spin it's wheels in Neutral
haha, yeah f**king annoying, but normal for a fwd :lol:
Yeah did the same thing with my daily the other day. But they were going a little faster the usual and was stopping when I put the clutch in... figures I started it in first..
You'll find once the gearbox oil warms up they'll slow down / stop.
Eltnot
Post by Eltnot »
Fair enough, thought it might be normal. Just wanted to make sure.
