Ac gas going.
- payaya
Ac gas going.
Ac is taking ages to cool down during a hot day. Is there a place where it leaks commonly? If not I will just refill.
Re: Ac gas going.
On the compressors. Ive looked at 4 and they all the bolts that hold it together had come loose and slowly leaked gas out, normally tell by all oil build up at the bottom of it.
Re: Ac gas going.
Lightly brushing soapy water along the A/C components?
Continuous bubbling effect can suggest a leak.
Re: Ac gas going.
This ^^
- payaya
Re: Ac gas going.
Nah it's never been refilled before and I've noticed in the last couple of years the cooling is getting worse. Just need a refill due to age.
But does it commonly leak from anywhere?
Re: Ac gas going.
Agree. Octopussy needs refilling
Re: Ac gas going.
Can leak from any of the joins. The FTO system usually leaks where the joins are to the condensor.
- yotka
Re: Ac gas going.
Just open the caps to the valves, and check for leaks as well.
Mine was due to an old valve, above the engine belt.
Got it replaced + a regas and its all good again.
- payaya
Re: Ac gas going.
Got my system gassed for $70 working like a treat!!
- FTO-BOY
Re: Ac gas going.
anyone know a cheap place in sydney for re-gasing?
- payaya
Re: Ac gas going.
Won't believe this but all the gas has leaked out. The condenser mounting brackets are loose and started rubbing against the temp sensor bolt mounted directly in front of it. Bloody joke the way it's mounted. Whos got a new condenser for me?
- yotka
Re: Ac gas going.
payaya wrote:Won't believe this but all the gas has leaked out. The condenser mounting brackets are loose and started rubbing against the temp sensor bolt mounted directly in front of it. Bloody joke the way it's mounted. Whos got a new condenser for me?
Not sure if mine leaked, but, its hot air for me now, after 5 months or so.
- payaya
Re: Ac gas going.
5 months since last regas? A dye should have been added on your last fill so you should see it somewhere.
Ended up getting my condenser repaired for $30 and going strong.
