Climate control or NO Climate control
NO1DEVIL
Post by NO1DEVIL »
Opinions anyone? Does anyone have 2 FTO's that i can sit in to see and feel the difference? xD
Re: Climate control or NO Climate control
the only difference between the 2 is that one automatically adjusts the temperature according to what it reads it as being outside.
If you were to compare A/C (Climate or not) to no A/C, then that is a big difference, and no difference to any other car with/ without A/C. Or simply not powering the A/C for that matter.
NO1DEVIL
Post by NO1DEVIL »
So manual is pretty much what i have now in my normal car ?
Correct.
To brielfy compare.
You get in to a car with normal dial operate air con. You select the speed of how fast you want the fan to work in order to cool the car down, as it gets colder, you select a lower speed.
In a Climate controled car. You press Auto and the temperature in which you wish the inside to be, it will go to work, adjust the speed of the fan automatically until it is the correct temperature, and then keep adjusting to keep it at that temperature.
Difference in the end is 1 button that you have pressed instead of fiddling around with many dials and switches, etc.
I always fiddled with the controls anyway, so the difference I find is the nice little digitial read out and direction of air from which vents.
Ive got both. They both do a good job. I never adjust the dials anyway, so I find it makes absolutely no difference.
