Rear wheel bearing
Leigh
Rear wheel bearing
Post by Leigh »
Hey crew, I am looking for a rear wheel bearing. So far I've only found a complete hub from japan, just wondering if anyone has any part numbers or if they know another type of car that uses the same bearing. thanks!
Jeff
Post by Jeff »
Sorry Leigh,
But at the moment I am waiting for a full hub from Japan.
Mits promised 3 weeks but so far it is 4 and no sign yet.
Jeff
You can get them from Camskill in the UK:
http://www.camskill.co.uk/products.php? ... b48s12p167
RallyMad
Post by RallyMad »
http://www.camskill.co.uk/products.php?plid=m3b48s12p0
THe above link is actually to the main page of parts from camskill for the drivetrain for the FTO which I think may have been the link Supplanter meant to post, not just the fronts. I found it interesting to see that a different rear wheel assembly is required for the cars with or without ABS, must be to accomidate the sensors? :?:
Leigh
Post by Leigh »
I got the Bearing number: DACF1085 Koyo Japan.
Rang a few bearing shops and a no go, so I'm just gonna get my japanese friend, to get one of his friends who works at nissan over in japan to send one over... Might get 2 if they are cheap enough, just in case.
Leigh
Post by Leigh »
The FTO is back on the road! yay!
I just sedated my withdrawls with a spritely night run.
(no naughtyness tonight though)
Just for anyone who may need it, The part number for the hub is:
MR131217
Part cost 15,200 yen. ($200)
G1
Post by G1 »
what are the symptoms of a worn rear wheel bearing?
i am getting some knocking noises only when I turn left, it's either my exhaust tip bainging against the rear bar, or i figure it could be this wheel bearing thing, coz when i got my gearbox fixed, the guy mentioned that he heard what could be wheel bearing noises frlom the back..
Disrespect is easy. Respect is the difficult road to take.
Leigh
Post by Leigh »
with my one I actually hit a curb pretty hard, I jacked it up and i could wobble the wheel quite a bit. not quiet sure about "worn" bearings as opposed to "crunched" bearings :P
RallyMad
Post by RallyMad »
G1 wrote:what are the symptoms of a worn rear wheel bearing?
From my experience G1 the sound from a worn wheel bearing is more of a schreeh (spelling?) than a bang or knock. Your noise, especialling as it's when you turn left sounds more like a CV. THey can knock and go on for a while warning you that they may need replacing or rebuilting shortly.
G1
Post by G1 »
this might be a stupid question but are there CVs at the back? coz ive only had problems with CV at the front in my past experience
