non fto inside
non fto inside
hey guys, havnt played with ftos yet but am playing with a lancer and pland on swapping some fto parts into it so i guess it came time to join an fto fourm to see what others have done and see what can be done with them..
just a quick pic. cheers john
- Kustom
Re: non fto inside
Hey Mor31
Haven't seen you post for a while, but not on the Lancer forums as much.
- spetz
Re: non fto inside
Welcome to the club
Re: non fto inside
Those rims suit that lancer 100%, good fuckn choice!
I commend you lad, welcome!
- Supplanter
- Eltnot
Re: non fto inside
And brakes....Supplanter wrote:You could always put an FTO engine in it
Re: non fto inside
Yup, I got a set of GPX brakes that would fit in there nicely...
- BorepYano
Re: non fto inside
FTO seats
Re: non fto inside
thanks guys. im doin a 5 stud swap on the coupe, i have the rear almost sorted but just need the left rear arm as the one that came with the brakes is bent. also looking to see if the front hubs will bolt up to the lancer, i have 294mm 8th gen vr4 brakes to go on the front. i have a 4g93t thats just waiting to be built and droped in but saving for a new family car so its on the slow, plan on using the wifes car as my daily when we get the new car. its a lancer coupe again but with a pissy 1.5 so i would like to maybe do a 6a12 swap into that just to make it better to drive and go nuts on my coupe.
if any one has a rear left arm or front hubs for sale be sure to let me know.
cheers
cheers
Re: non fto inside
WTTC
Another option you can do if your after that MIVEC feel is:
Breathing mods.
Mild cams/tune ECU.
Breathing mods.
Mild cams/tune ECU.
Re: non fto inside
ok well, i picked myself up a mivec fto. so now doing the 6a12 swap into my car and not the wifes. the fto was in a little bang but all good, sorta, lol.
when taking the engine cover was taken off it showed us a hole in the cam cover where the engine cover bolts on, its about the size of a 10c coin, lucky the peice was still attatched to the engine cover so will just weld it back on. planing on swaping the rear brakes over tmz and engine in a few weeks time, need to get block hugger headers, engine mounts (thinking solid), clutch cyl and fix head. all belts and what not are new but will check anyway. any QLD want to help feel free to let me know. pics soon
