Hi guys,
my automatic transmission fluid is in need of a change and I'm looking at getting it completely flushed out by a specialist instead of doing it myself.
Is it worth going to a specialist to do this, or will doing it myself be fine?
Also, where can I buy some good quality fluid from? I think it's SPF-III I need?
Cheers
Where to buy AT fluid / worth going to specialist?
- -Nighthawk-
- -Nighthawk-
- zuihoujueding
Re: Where to buy AT fluid / worth going to specialist?
not sure on how to change auto oil but you pretty can get those oils at almost any auto shop like autobarn, supercheap auto, repco.
Do it yourself mate, its a piece of piss.
This video does the perfect job of explaining it, although it is on a Honda.
The pipe points to do this on the FTO are near the actual filter on the box & run into the radiator. Just use them as your fluid in & fluid out points. Dextron III is fine.
- -Nighthawk-
Thanks for the replies, I might have a go at it this weekend
So Dextron III short is DX3?
If so is this a good fluid to use?
http://www.supercheapauto.com.au/online ... escription
Cheers
Cheers
- zuihoujueding
just get the most expensive oil u can afford on the shelf. Otherwise, this is also good.
If you can get hold of Amsoil or Redline ATF then I would go for that above something like Comma, not sure about the valvoline but it is a DX3.
Mitsubishi used/recommended diaqueen I believe but it's hard to come buy and or expensive.
- Storm
There's a bit in the Mitsi manuals about how to fully drain the system by using those points and running the box through the gears. It takes a lot of bottle to let your box run to dry though! IIRC it means running the car for about 30 odd seconds. I think I managed about 20!
