spark plugs
spark plugs
What are the best ones to use ??
I did a search didnt really find an answer....
- smorison
- The Godfather
- smorison
- The Godfather
They actually aren't that easy to find at normal autospares shops, but you can get them from most Toyota dealers. Probably won't be cheap from them though, so it might help to do a bit of looking around and see who stocks them in Adelaide. If you were in Sydney, I'd be able to help you out more.
[img]http://users.bigpond.net.au/sentry/sig.jpg[/img]
- smorison
- The Godfather
- smorison
- The Godfather
- FTO338
Hey steve, apparently theres 2 type of irridium spark plugs for FTO GPX from NGK. So are you refering to IRWAY7 ???
where can you get them in sydney? im in the homebush bay areaTheSentry wrote:They actually aren't that easy to find at normal autospares shops, but you can get them from most Toyota dealers. Probably won't be cheap from them though, so it might help to do a bit of looking around and see who stocks them in Adelaide. If you were in Sydney, I'd be able to help you out more.
Disrespect is easy. Respect is the difficult road to take.
- smorison
- The Godfather
- FTO338
- RichardH
Was that dyno test comparing NGK Iridiums against brand new stock ones, or against stock ones with X kilometres on the clock?smorison wrote:i use NGK irridiums and have dyno tested them they provide a 2kW gain
And were the originals platinum rear, non-platinum front, or platinum all round (like many garages put in these days)?
Cheers.
- Rich
