Strut top
- payaya
- phunkydude
Re: Strut top
It's pillowball upper mount, to be exact.
That tein set, cheapest you can get through locally is from perfectrun au/jp delivered to your door for around $250 or less. You'll need to email them on the product as Tein's is not listed on their web which only got Cusco's there.
Ben is using them. He bought it through camskill which is dearer.
For usd$130? where?
For usd$130? where?
- payaya
Re: Strut top
The generic terms if strut top.
They are the same as a mirage/lancer item
Quick search
http://www.autodynamic.com/detail.asp?p ... 38-31PFR-2
Quick search
Re: Strut top
Yeah I use those & thats a great price. Freight will probably kill it thou, yanks are obsessed with using UPS which is usually a $70 hit just to get them here.
- payaya
Re: Strut top
Obviously the old tops are not used?
- payaya
Re: Strut top
Still under 200 sounds good. How much are the oe ones?Bennoz wrote:Yeah I use those & thats a great price. Freight will probably kill it thou, yanks are obsessed with using UPS which is usually a $70 hit just to get them here.
- phunkydude
Re: Strut top
http://www.camskill.co.uk/products.php?plid=m3b0s10p365
The OE is made of rubber bush which replaced by pillowball in Tein's.
And the mounts on Tein is metal instead of rubber. (harsher ride, of course).
And, i heard that Tein's bearing are prone to fail after some time creating noise, which needs to be replaced.
- payaya
Re: Strut top
How prone to failing?? How much are the oe bushes here?
- phunkydude
Re: Strut top
Not sure about locally. I think you only able to get it from local mitsubishi. Try phone them for price.
Google "tein pillowball bearing noise" , plenty of discussions in forums.
FYI, tein's coilovers for fto are using the same pillowball upper mount.
Re: Strut top
I've had em on my car for 6 years & never had a bearing noise or issue. Just need to lube the top ball from time to time as per Tien specs.
btw they can be used on any strut, not just Teins.
- payaya
Re: Strut top
Considering my stock strut tops have seen their days I def will get some.
Re: Strut top
If ya wanna go halves in freight, I'll get a set too. The rubber units in the misses car are shot to sh*t too so I need some replacements.payaya wrote:Considering my stock strut tops have seen their days I def will get some.
- payaya
Re: Strut top
Sounds good mate! How ya want to do it?
- SchumieFan
