Moving Battery
Boris
Moving Battery
Post by Boris »
How many people have moved their batteries into the boot?
How would you run the wiring, under the car, or throught the firewall and under the carpet?
Does the battery have to be any special battery? Because the workshop that i asked said it does, and it will cost lots... but i think they were just avoiding the job.
With my normal battery, if I get battery box will it be ok for track use?
Also, should I do this myself, or leave it up to the pro's... what kinda pricing am I looking at if I do ask a mechanic to do it? Cos most of them over quote by tons, or don't want to do it. 8O
SilentBob
Re: Moving Battery
Post by SilentBob »
Boris wrote: How would you run the wiring, under the car, or throught the firewall and under the carpet?
I would imagine though the firewall and then under carpet would be the safest and most 'long-life' solution....
as for difficulty I dont imagine it to be to hard with the correct cabling...after all, its similar to running the power from the existing battery to say an audio amp in the boot/rear of the car, just in reverse(kinda)...
as long as the battery was mounted securly and protected I dont see why a 'special battery' would be needed, the extra 1-2 metres of wire wouldnt hinder the performance by much if at all
my 2 1/2 c(hey my knowledge and guesses are worth more than just your average 2c ;) )
SilentBob
GPXXX
Post by GPXXX »
my battery had to be moved to the boot because otherwise there'd be no room whatsoever to mount my turbo...
all cabling is run beneath the carpet... i had to switch to a 660cca battery and it's a massive bastard but i was assured that i WILL need it... *shrugs*
should come in handy when i get the rest of my ICE system sorted out hehe... :twisted:
Boris
Post by Boris »
So, the cables then runs on the passenger side of the car, ubder the carpet right? Is it there like a lump where it runs?
Hmm, I shall have to have a look at some setups at the cruise.
smorison
The Godfather
Post by smorison »
its easy to do....
the 100AMP cable is about 45.00 per meter and you should by extra (say 4 meters) to make sure you don't have to try and make a join somewhere...
running through the firewall is easy just make sure you have a grommit in there to stop it rubbing through the plastic shielding...
mount it with a battery box in the boot drilled through the floor to ensure that its say and stable.
i would also add a fuse / kill switch to the outside of the box to make things extra safe ;)
Jono
Post by Jono »
yes, boris
i think u should be able to do it..
the only thing is, u need to get a decent ground in the boot,
u might have to Scratch off some paint and get some special' paste or paint for electrical purposes so that grounding wire connects to the chassis really well...
I had Evo motorsports redo my grounding.
Jono
elmo
batteries
Post by elmo »
The "special" battery they mentioned may be a sealed one so in the event of a rollover no acid leaks out, although that will probably be the least of your worries.
I think there is a regulation that you have to change it if your battery is inside the car or the boot.
I've been wrong before though.
efteoh
Post by efteoh »
just curious, what would the rating of the fuse be if i relocated the battery to the boot? 60A?
mxysxy
Post by mxysxy »
Hey guys, as a newbie, I will stick my apprentice question in here,
What part of the car is the firewall?
ruchi
Post by ruchi »
the piece of metal that divides the engine bay from the cabin.
MIVEC is My Friend :D
mxysxy
Post by mxysxy »
thanks Ruchi, you are a Sensei
smorison
The Godfather
Post by smorison »
efteoh wrote:just curious, what would the rating of the fuse be if i relocated the battery to the boot? 60A?
you wouldn't need a fuse...
connect it directly to the existing positive wire..
earth the battery to the body in the boot..
put a safety cut off switch on the battery... also makes it easier for doing electrical work on your car ;)
barfy
Post by barfy »
If your doing this because of the CAI intake pipe from UAS theres no need to move the battery to the boot. All you need to do is make the top bracket that fits on top of the battery smaller so that the bar will be brought in closer and then just drill a new hole in the battery tray for the bar to go into :)
I took it to auto place asking them to move my battery to the boot, but they came up with the above idea which only cost $30 :)
smorison
The Godfather
Post by smorison »
mines going in the boot to move weight to the back of the car and for a couple of other reasons you'll all find out about eventually ;)
ruchi
Post by ruchi »
can I have a guess? :D :wink:
mxysxy
Post by mxysxy »
man, we should orgainise a turbo kit group buy..
smorison
The Godfather
Post by smorison »
ruchi wrote:can I have a guess? :D :wink:
sure ;)
smorison
The Godfather
Post by smorison »
mxysxy wrote:man, we should orgainise a turbo kit group buy..
who said anything about a turbo ;)
Jeff
Post by Jeff »
I paid $700 to relocate and a new heavy duty battery, and battery box. They ran the cables under the car but fixed them throughout. It was a little expensive but the professional job was worth it.
The turbo is going in now.
Jeff
Jono
Post by Jono »
Wow,
thats allot..
For me, a new battery $80 + Box $30 + cable $50
And a professional to reground in the boot... $30
so all up $210
Jono
Jono
