Oil leak on rear passenger side of engine
Was tiny leak from cam seal
Re: Oil leak on rear passenger side of engine
Looks like it's be coming from the cam seals (Black circular shape just next to the hose clamp pictured.)
There are 4 of them on that end of the motor & if they're gone, then chances are the 4 other seals at the timing belt end of the engine are gone / going too.
Relatively cheap to replace, but labour is gonna cost ya. Very time consuming.
Cheers Bennoz
Are there any special tools needed to replace the cam seals? If its going to be a lot of labour i will get my mate to do it for me over a few days for free.
Cheers Nick
Cheers Nick
- vipfto
FTOnick wrote:Cheers Bennoz
Cheers Nick
na just labour really might as well do all other seals/timing belt/ water pump etc while your in there pain in the arse job but you only want to open it once
I had my timing belt done about 3 months ago sucks they didn't do it then i guess
They said they did some seals on the 'front end' too when they did the belts but i guessed they missed this one haha.
- Sweep
Maybe get your guy to check the tappets to while he's in thier.
