block bored and honed.
81.5mm bore JE Pistons
1mm longer than standard Crower Rods, which gives a better rod ratio and allows you to rev higher
Light weight crank pulley
All balanced along with the crank.
Custom baffled sump to prevent oil serge
Custom head casket
ARP head studs
Ported Heads
Ported lower plenum
Ported Throttle body
Reversed upper plenum drilled for direct pot NOS.
Denso Iridium IK27 Plugs
MAGNECOR 8mm Ignition Leads
Custom HKS Cams 272/300
Uprated springs
Veiner pulleys
Alternator
535cc injectors
+ Spares, heads, cams, injectors, brand new plugs etc.....
£4500 ovno
Pickup from Lincoln UK.
