Just a quickie.
I've done some forum searching and either I am blind (likely), or don't know what to search for (also likely).
What dimensions of wheels (stud pattern, etc.) will fit on an FTO. I want to get 17s.
Just so I know when I am doing all my research...
Thanks
Edit: or even better, explain to me what the numbers mean so I know
bass_twitch wrote:Just a quickie.
Thanks
5(studs)x114.3(I believe is the radius or diameter (distance from centre of the wheel ) <--- can't remember school maths ). and the offset is up to you, this all depends on how far you want it to stick out of the guard, or into the guard for that matter.
damn iv had the same question wondering in my head, was just afraid to ask. because i thought i'd get told to use the search button which i did lols.
but just to add would rims with:
17x9 +38
17x8 +35
Fit because im eyeing a set at the moment.
and i'll know what sorta rims to look out for.
aznfto wrote:damn iv had the same question wondering in my head, was just afraid to ask. because i thought i'd get told to use the search button which i did lols.
17x9 +38
17x8 +35
the 17x8 will but highly doubt the 9's will they would need to be very low maybe high to low +20 and doubt they will fit on front
Ok so I have a wheel that I am interested in getting. It is 17 x 7.5, 5 x 114.3 but only comes in offsets 33mm and 45mm. Just wondering, would these fit and/or is there a way to make them fit?
