o2 sensor
- hhakan
o2 sensor
http://cgi.ebay.com.au/O2-LAMBDA-SENSOR ... 2c5a87757c
since its a cheap part and it can possibly save fuel. i was wonder is it hard to change it? im only getting about 350-400k a tank.
where is it located on the car? if i knew were to look i might be able to analyse it myself
- hhakan
Re: o2 sensor
looking at the picture it only looks like a bolt. is that the right part for the o2 sensor??
- Shane001
Re: o2 sensor
lol that's just a bung plug, fills the hole in your exhaust if you remove it
- bduffman
Re: o2 sensor
it will look like this http://img139.imageshack.us/img139/2154/214218ug.jpg
and thanks to ultra racing http://www.showoffimports.nl/product.ph ... ctid=33365
you can see the wire coming from the exhaust in the top middle of the pic
i tryed to change mine but being so old its sorta seized up
- Shane001
Re: o2 sensor
Try getting a spanner to it while it's hot from the exhaust to loosen, then let it cool down. Otherwise you will need to get some heat directly on it.bduffman wrote:i tryed to change mine but being so old its sorta seized up
- Shane001
Re: o2 sensor
Oh and that pic is so wrong...bduffman wrote:it will look like this http://img139.imageshack.us/img139/2154/214218ug.jpg
The O2 sensor needs to be in the air stream of the exhaust, not spaced 1 to 2 inches away!
- bduffman
Re: o2 sensor
yea i just google serched o2 sensor and picked the first one that was in a exhaust system didnt really bother looking at it to much
- Shane001
Re: o2 sensor
- hhakan
Re: o2 sensor
I knew it was too good too be true
- bduffman
Re: o2 sensor
yea you will need to buy a universal 4 wire 02 sensor and rewire it to the old one theres a few threads on here showing witch one to get and how to install it
