BEST OIL TO USE
BEST OIL TO USE
Guys,
Whats d best oil to use for 6A12 Mivec engine?
Eoh
Eoh
- smorison
- The Godfather
Re: BEST OIL TO USE
i use motul 6100 a fully synthetic oil. its a bit more expensive than others however my car gets "driven" so i like the extra protectionHRD2BQT wrote:Guys,
Eoh
- lal
Re: BEST OIL TO USE
this explains a lotsmorison wrote: i use motul 6100 a fully synthetic oil. its a bit more expensive than others however my car gets "driven" so i like the extra protection
does this explain that "weird stuff" you discovered in your car when it was bought? as that old thread specified ("weird stuff found in your FTO?")
hehehe...
<FONT color=#ff00ff size=2><FONT face="arial, helvetica, sans-serif" color=#ff00ff size=2><FONT size=2><FONT size=2>
<P> </P></FONT></FONT></FONT></FONT>
- smorison
- The Godfather
Re: BEST OIL TO USE
goodlal wrote: this explains a lot![]()
lal wrote:
does this explain that "weird stuff" you discovered in your car when it was bought? as that old thread specified ("weird stuff found in your FTO?")![]()
hehehe...
no, nup, what are you on...???? lol !!!!
i can't find any relationship between the way i drive my car and a pack of condoms...
lol
- lal
Re: BEST OIL TO USE
yeah.. probably doesn't explain how you drive...smorison wrote:goodlal wrote: this explains a lot![]()
hehehe...
lol
jsut shows that the car always ends up with owners who likes extra protection... you with oil.. the previous owner with a different kind of protection in mind
anyways... back to the topic..
yeah.. many threads on this topic...
I use Shell Ultra... one of the cheaper fully synthetic type...
since i do 30k kms a year and oil change every 5K kms... it adds up... so i use that as it serves the car very well.
- smorison
- The Godfather
Re: BEST OIL TO USE
hey that's really coollal wrote: yeah.. probably doesn't explain how you drive...
jsut shows that the car always ends up with owners who likes extra protection... you with oil.. the previous owner with a different kind of protection in mind![]()
yeah anyway back on topic before i have to sick the forum nazi on myself
I recently switched to Penrite HPR5 and am quite impressed. It's semi-synthetic, rated a 5W-40 and is priced well.
I choose this oil for 3 main reasons:
1) it's low temperature viscosity (5W) which provides a much smoother engine in the morning. You can definitely notice this over other 10W and 15W oils.
2) it's high temperature viscosity (40) which offers better protection than the numerous "30"s that are out there and keeps your tappets quiet unlike many of the oils rated at "50".
3) It's under $40, whereas many others in this class are around the $60 mark or more.
MIVEC is My Friend :D
- RichardH
- Theremin
I use Mobil 1 5W-50, but I'm sure Motul is also good (or better). See here for info re. oil...
http://www.ftoaustralia.com/modules.php ... opic&t=775
- payaya
5W40 is a nice oil for variety of condtions, but its cold visocity is too thin for the FTO!
Use what mitsu recommend for the FTO. If you dont you might just use a 0W40 if you dont care!
10W40-50 is well good enough for the FTO.
using a 5W40 will cause lower oil pressure than a 10-15W40 at startup, which means lower protection.
- wildfaye
I have been using Mobil 1 5W50 since new. Great oil!
Been thinking of using Mobil 1 0W40 for better consumption but was wondering
if a 100k engine would be able to take the 'thinness'?
Morever, we done have anyting below 25deg in hot singapore all year round. so 0W wun possible be needed...rite
what do u guys reckon?
- RichardH
I can't actually find anything in the FTO factory/service docs about xW-whatever. All it says is "SG or higher".
But I believe the general climate temperature has a lot to do with oil selection. Lowest/highest expected outside temps affect it.
Like, our funky new Magna AWD 3.5l V6 lists the following:
-30 degrees to 40 degrees: 5W-30
-25 degrees to 40 degrees: 10W-30
-25 degrees to 50+ degrees: 10W-40 or 10W50
-15 degrees to 50+ degrees: 15W-40 or 15W50
-10 degrees to 50+ degrees: 20W-40 or 20W50
Bear in mind these are for a big V6 that doesn't rev as high as ours. So don't take this as FTO-specific. But you get the idea.
So basically, if I were to move from Perth to Canberra, I'd reconsider oil selection! And buy lots of thermal underwear.
For mine, I use what the local RalliArt garage recommends. Simple as that. Hence the 5W-50 oil.
- Rich
- Rich
You're right on both accounts Richard, Mitsubishi don't list a rating of xW-xx for the FTO they only list that it must be of a "SG" grade. Likewise you should choose your oil not only based on the car you have but also the environmental conditions.
Personally I find a 10W is fine in the summer months but a 5W makes a noticeable difference in the cooler months (Melbourne)
. But I normally stick to a upper limit of 40 all year round, as I find if I go to a 50 the tappets get louder.
- RichardH
Yeah, I'm happy with 5W-50, what with it being sodding cold overnight in wintery Perth. By sunbaked Aussie standards anyway, hehe.
And my long-held suspicions about my GPX's engine noise have been pleasantly confirmed... it was in fact all "old clutch" noise.
Just had a new standard clutch fitted, and it's idling and revving as quiet as a mouse now. I can only hear one valve out of 24 chattering quietly away to itself.
The old thrust bearing was raspy and noisy to turn by hand after it had been replaced. And all the springs in the clutch plate were rattling around very badly. It's sooo nice now. Lovely quiet engine (for a GPX
- Rich
- Rich
Jono, the first number (with the W) relates to the cold temperature. The lower the number the more viscos it is at a lower temperatures. i.e. 5w will be more viscos than 10w at lower temperatures.
The second number relates to higher temperatures, the higher the number the better the oil will protect your car in higher temperatures.
You can however go too far. If you use an oil that is too viscos in the cold your engine may not get enough protection in the morning and the same goes for the opposite side of things in the heat.
Having said that, when choosing an oil you should consider the type of engine you have, the condition it is in, the environmental conditions of where you live and how you drive the car.
There is no one "perfect" oil and hence why so many people are using such a wide variety.
