Relief of boredom for Gholdwayne
- Gholdwayne
Ok, so im bringing the car in to UAS for a timing belt service which they said is an all day job since the car has hit 100,000km... Going tomorrow(Thu 3/2/11) and will be there by 9am...
Now what the hell could I do while waiting? Any interesting things around 7hills? Would someone hang out with me ? lolz...
Hopefully though, they would allow customers to watch the job being done.. I'll just bring loads of food so I dont starve and some pineapple juice...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: Relief of boredom for Gholdwayne
lol... where they are, there is exactly ZERO things to do
You could either walk round the corner to the Top Gun lead factory for a look, or keep on walking down to the Beer Factory in Tollis Place. Brew yourself a batch
- Gholdwayne
Maybe I should get ignition leads...
But question, is uas going to have to remove the intake manifold ?
And, the fto leads in the top gun catalog, would it work for both mivec & non mivec?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- sublime19
- Sooty!
Well to change the leads yes, you need to take off the manifold and gr & gpx ones are different, not sure about the ones you're talking about.
Tell John his 'poker buddy' said hello
- vipfto
Gholdwayne wrote:Ok, so im bringing the car in to UAS for a timing belt service which they said is an all day job since the car has hit 100,000km... Going tomorrow(Thu 3/2/11) and will be there by 9am...
Or you could buy some mags and spend some quality time with yourself in the toilets
- Gholdwayne
Not a bad ideavipfto wrote:Gholdwayne wrote:Ok, so im bringing the car in to UAS for a timing belt service which they said is an all day job since the car has hit 100,000km... Going tomorrow(Thu 3/2/11) and will be there by 9am...
@Subs - I knew the manifold has to be removed for the plugs, I was just wondering if they had to take it off in the process of getting to the timing belt replacement(by the looks of it, they might not need to, unless there was a cam box leak).
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- vipfto
and you dont have to remove manifold either but does make it easier with a little more freedom to move,
You will find its just a lengthy process nothing really interesting but a great way to learn
- Gholdwayne
Fark! Hate it when work is being done to my car and i cant watch... oh well...
Might also get a dyno run for $95 when there is time.. wohoo!
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Gholdwayne
ok.... Turns out the guy working on my car has never done an fto timing belt...
Fingers crossed errthing'll be ok
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- FTO_GPvR
Yep fingers crossed, hopefully everything goes good manGholdwayne wrote:ok.... Turns out the guy working on my car has never done an fto timing belt...
- Delvance
Prepare for pistons punching valves then!! The fto timing belt job is quite different in that its a v6 but mounted in a fwd platform ie south east.
- sublime19
- Sooty!
lol, should be good. They've worked on performance cars of all sorts, you're in good hands Ghold
- Gholdwayne
Delvance wrote:Prepare for pistons punching valves then!! The fto timing belt job is quite different in that its a v6 but mounted in a fwd platform ie south east.
I seriously hope thats just a fun scare
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- FTO_GPvR
How did it go mate? Did u get your car back?
- AJ
I only just got to this now but when my car was getting worked on there I got them to take me to castle Towers and I just watched movies all day.
- Delvance
Gholdwayne wrote:Delvance wrote:Prepare for pistons punching valves then!! The fto timing belt job is quite different in that its a v6 but mounted in a fwd platform ie south east.![]()
- Gholdwayne
Fkn hellDelvance wrote:Gholdwayne wrote:Delvance wrote:Prepare for pistons punching valves then!! The fto timing belt job is quite different in that its a v6 but mounted in a fwd platform ie south east.![]()
I seriously hope thats just a fun scareumad
@tyson - not yet man, the guy realised that the water pump replacement needed the compressor nd front extractors nd errthing in btween to b removed... thats when i knew he never done an fto timing belt before...
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Definitely a n00b. Extractors don't need to come off.
- Gholdwayne
Thats what the guy said, but maybe he would've figured out that the extractors need not come off...
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- FTO_GPvR
This guy sounds like he doesnt have much experience with FTOs. So when do u get your FTO back? Today?
