I'm new to the forum and this is just a note to say hi and to ask a few questions. I don't own an FTO at the moment but will be soon.
What sort of HP is the 6A12 engine capable of with and without internals? Why I ask is figures that I've seen so far (i haven't seen that many) don't seem big. Is weight more the advantage with these cars than actual power. I was watching a Youtube vid of one going around Eastern Creek and it was 170HPATW. Albeit it was staying with a 400HP Supra. It was actually that car that makes me want to buy one. It is an awesome FTO.
Does the 6A13 twin turbo bolt straight in or do you have to modify? I haven't seen any with the 6A13 installed which leads me to think it's not a good option. As they are adaptive learning gearboxes, is there software that can program shift patterns in the autos? Is torque steer an issue with FTO's?
What I plan to do is buy one as well as a another engine and just do it up and bolt it in. My main focus is engine and drive chain. I'm just doing a little homework before starting so I have scores of questions but if someone could answer these I would greatly appreciate it.
Thanks in advance
Steve
Newbie FTO questions
Steve0249
- vipfto
Re: Newbie FTO questions
check the turbo thread to answer 6a13 Q's
and yes it is a power to weight and handling factor that make it reasonable on track. Also you can extract around 150KW at the wheels with N/A form and yes torque steer can be issue if not addressed correctly.
But like I said search around the forums and you will answer all your Q's
Oh WTTC
Oh WTTC
- aza013
- NSW Coordinator
WTTC
And yes as above N/A you can get up to and maybe higher than 150kws atws.
Also another option would be the 4g63t as an engine swap.
The FTO's weight can be from 1100kgs - 1300kgs, it just comes down to what the FTO is ( GR, GPX, GPVR and so on ) and what is in the car ie subs and amps and so on.
- Kuran
That FTO you saw on youtube was shanes. He's on the forums here
Steve0249
I should have guessed the owner was a member. lolKuran wrote:That FTO you saw on youtube was shanes. He's on the forums here
So with internals would 200rwkw be acheivable? Just rods and pistons. Is the bottom end OK for say 200kw? If it is, that would be awesome.aza013 wrote:WTTC
- aza013
- NSW Coordinator
Well 200kws Could be done with noss but at the fronts as the FTO is fwd.
But without any addon's turbo/ noss I don't think you could do it.
Steve0249
OK thanks for that and I appreciate all the feedback so far.aza013 wrote:Well 200kws Could be done with noss but at the fronts as the FTO is fwd.
If you want big power, dump the 6A13 in. It'll be cheaper than stripping & rebuild a 6A12. Yes they 'bolt' straight in, but the plumbing & wiring can be a bit of work.Steve0249 wrote:I'm new to the forum and this is just a note to say hi and to ask a few questions. I don't own an FTO at the moment but will be soon.
Thanks in advance
Steve
Read my thread here:
viewtopic.php?f=22&t=15644
Steve0249
Thanks for that. How in blazes did I miss that. LOL. I must have been reading with my eyes shut.Bennoz wrote:If you want big power, dump the 6A13 in. It'll be cheaper than stripping & rebuild a 6A12. Yes they 'bolt' straight in, but the plumbing & wiring can be a bit of work.Steve0249 wrote:I'm new to the forum and this is just a note to say hi and to ask a few questions. I don't own an FTO at the moment but will be soon.
Thanks in advance
Steve
