Bigger rotors on stock GPX calipers?
- wildfaye
Has anyone tried this? Any fitment problems? Usage problems?
Any feedback appreciated!
Cheers!
Cheers!
- SilentBob
nah i replaced my front rotors, but just with standard sizing...
to replace with bigger some adjustment will need to be made to the mounting of the calipers(due to the limited clearance between them and rotors)..
steve mentioned that UAS were 'developing' a bracked to allow the fitment of a larger rotor to the fronts, but would more than likely also require having 17" wheels for the clearance side of things...
Im sure he'll post details at some stage
SilentBob
SilentBob
- wildfaye
Hi guys, I did a check on the DBA website and here are the results:
http://www.dba.com.au/dba_catalogue_200 ... ubishi.pdf
Under FTO, the fronts are 425.
Take a close look at the specs of the front discs.
Than look at 417 under Evo IV.
These fits 16" and the specific dimensions are all pretty similar, with the 417 being almost 20mm larger.
FTO DBA 425: 276x45x24x22.4x69x5
EVO IV DBA 417: 294x46x24x22.4x69x5
Now for the rears.
FTO DBA 547:260x41x10x8.4x90x5
I can't find a larger similar spec in the Mitsubishi range. But found these others instead:
Honda S2000 DBA 483: 282x40x12x10x64x5
Mazda 6 DBA2951:280x40x10x8x72x5
(both are pcd of 114.3x5 from memory and should fit perfectly by boring out the centre bore of the discs.)
http://www.dba.com.au/dba_catalogue_200 ... /Honda.pdf
http://www.dba.com.au/dba_catalogue_200 ... /Mazda.pdf
Any comments on these?
Now for the rears.
- SilentBob
im pretty sure those were the rotors that they were looking at using....
just need to work out how to shift the caliper back 1cm or so due to the larger rotors
wouldnt be hard and i guess thats why they developing it...
wouldnt imagine a HUGE improvment from this, but the cooling side of things would assist in reducing brake fade/repeated braking
- smorison
- The Godfather
one of the front struts is out of my car at the moment, we are building two brake upgrade kits...
Stage ONE:
* 330mm rotors
* Stock callipers
* mounting bracket for stock callipers
Stage TWO:
* 330mm rotors
* Brembo Callipers (about $700.00 extra for these)
* mounting bracket for new callipers
The Brembo's we are looking at come of a lotus elise from memory and are fantastic - i've held them... mmmmmmm brembo's.....
i will have more information by the end of the week...
btw current UniqueFTO projects are:
* Adjust exhaust CAM gears
* electronic Waterpump
* Tranmission Radiator[/b]
Stage ONE:
* 330mm rotors
* Stock callipers
Stage TWO:
* 330mm rotors
- SilentBob
- wildfaye
Transmission radiator?
Cooler u mean? I have one installed, I am not sure of the temps after the install, but the gearbox is def smoother.
I have an engine oil cooler installed as well.
Those 'Cusco' front struts with brake cylinder stopper: are they avail yet?
I have a original cusco strut and was wondering if i can get the mounting with the cylinder stopper and bolt on the existing strut?
- SilentBob
if the 'brake master stopper' is the same as currently on steve's car it doesnt attach to the strut bar, but the wall in the engine bay next to the brake cylinder
though, you may have to check your car isnt 'different' like mine, because when we fitted the strut brace my brake cylinder is further towards the front of the car due to a larger brake booster, hence a 'stopper' like this would not be 'doable'
SilentBob
SilentBob
- smorison
- The Godfather
SilentBob wrote:if the 'brake master stopper' is the same as currently on steve's car it doesnt attach to the strut bar, but the wall in the engine bay next to the brake cylinder
SilentBob
ok
transmission raditor = overheating on the track need to cool it down
brembos are larger twin pots
adam: we should test fit one to yours it is adjustable so it should fit.
the upgrade kits are for 17" wheels or larger....
- wildfaye
errm...bob...i am not sure if we understand each other correctly...
so...lets try again...
the brake booster is the one on the fire wall.
the brake cylinder extends towards the front of the booster.
the brake cylinder stopper is a bracket that prevents the cylinder from moving hence reducing 'sponginess': this is supposed to be an adjustible bracket rite?
the project being done up is supposed to have:
the strut bar mounting(brake cylinder side) which will extend downwards to the side of the cylinder(next to the wall) will incorporate the the bracket to hold the brake cylinder hence prevent movement.
am i rite?
since the mounting + bracket is supposed to be made from a cusco bar, would it be possible to buy the 'new' mounting that incorporates the brake cylinder stopper? and bolt up the cusco bar i already have?
smorison: any pics on this would greatly help...thanks!
am i rite?
- smorison
- The Godfather
- smorison
- The Godfather
- fto617
hey stephen !
what actually does brake upgrades do???
coz i reckon the stock brakes are not good enough man !!!
oh and when is the cf bonner group buy goin ahead???
i'm in urgent situation !
crashed my car yesterday
killed the front bumper brackets
and the bonnet jsut bent !
damn man i hate driving in rain >.<
lucky it skidded when it was goin at only 20km/h
not bad damage just mispositioned bumper
- wildfaye
What i meant was:smorison wrote:wildfaye wrote:Ohhh jezzz...and i tot i could get some custom made brake stopper...
hmm...
I tot i was able to buy the left 'cusco' modded strut bar holder that incorporates the adjustable brake cylinder.
now that the project has been dropped...pop goes my bubble...
hmm...btw, u peeps considering making a fto specific brake cylinder stopper?
Bit confused here but are u saying your brakes are to blame for your accident?fto617 wrote:hey stephen !
[img]http://users.bigpond.net.au/sentry/sig.jpg[/img]
- smorison
- The Godfather
I currently use the stock MIVEC (GR callipers are smaller) with racebrake pads and have no problems stopping even on the race track... The Callipers are the same as those used in EVO's (upto evo4 or 5) so they are definately upto the job... i have ZERO brake fad even after 15+ minutes on the track....fto617 wrote: what actually does brake upgrades do???
as much as i'm probably talking someone out of our brake upgrade kit (buying it for possibly the wrong reasons) i would say upgrade your pads to a better quality pad and check your rubber it's possibly not upto the job... most importantly always be alert when driving and ensure you keep a safe distance between yourself and other cars especially in the wet.
things to consider:
brake fluid - should be atleast dot 5.1
brake pads - don't skimp on these!!!
rotors - are they screwed do they need machining?
tyres - are they worn out??? are they a cheap tyre?
so i guess your wondering why we are doing a brake upgrade kit now... well i'm planning to (and i'm sure others will as well) run semi slick / slick tyres on the tracks from now on... as there is more rubber on the road we need a better braking system that won't overheat with trying to slow down the car with the added traction...
