front driver tyre keep losing pressure
- zuihoujueding
Not sure what is the cause. did not see any visible puncture marks. My mate blame on the side wall. now that all tyre shops are closed. Does the green product "slime" solve my problem?
always pump my tyres to 34psi and it dropped to 26psi in matter of days.
- Lawso
- Penis Fingers
- Storm
Re: front driver tyre keep losing pressure
lol.
Replace the valve mate.
- Kustom
- Lawso
- Penis Fingers
Or his engine mount...lawsochap wrote:could be your head gasket
- Lawso
- Penis Fingers
maybe a shredded drive belt, or bent, possibly snapped valves
*likes this ^*
- Lawso
- Penis Fingers
check the front cam seal for leaks, possibly hitting the tire causing a hole, also a common problem with tyres losing pressure
- Kustom
lawsochap wrote:check the front cam seal for leaks, possibly hitting the tire causing a hole, also a common problem with tyres losing pressure
- zuihoujueding
- SchumieFan
- payaya
Tyre beed to wheel is not sealing right. $20.00 bucks to do and they will replace the valve.
- SchumieFan
sounds a bit right with balancing
obviously not enough monkey snot on it
- MichaelT
Slow leak for sure...spray some soap water around the rim and rubber profile...formation of bubble indicates leakage...though if it's really a small leak on the tyre...and it's those cheap Falcon brand one, just buy new one...unless you got a Pirelli or Bridgestone Potenza!!! If it's around the rim, sure bet is get it repaired...
- Lawso
- Penis Fingers
- zuihoujueding
Found a small nail and fixed the hole for $20.
next day found a another small nail on the other front tire.
Went back and got fixed for free.
- Lawso
- Penis Fingers
