Help ! Power Steering Rack !
Bamboo
Post by Bamboo »
The mechanic called me this morning and made assumption that the power steering rack is broken and needs to be either worked on the seal (no idea about this , please help out, novice here) or change the whole rack. He said the hosing system is not good (bad condition). He said *fingers crossed* hopefully just the seal section needs to be done and if not, will have to check for the second hand use to replace a new used rack (if reliable, can't tell really whether if the rack is good enough). Or find it somewhere else and get a brand new rack either import it from Japan or other recommendations that you guys can help out. Thanks a lot, urgent.
Bamboo
Re: Help ! Power Steering Rack !
Post by Bamboo »
Excessive fluid leakage because of the rack. Kept leaking, boot cracked as well
Ive got spare PS racks if you need one.
cheers
    MH999
    Post by MH999 »
    I have one also $120 pickup from perth .Thats only if he cant fix the seal section lol.Its a pain in the arse to remove the steering rack.
    Bamboo
    Post by Bamboo »
    is that a used rack ? hope it's reliable my friend :lol:
    thanks guys, will hit you back soon when I received the news regarding to my repair
