fuel
- hhakan
fuel
Is it okay to use E10 fuel on a 95 fto? Or should I get the expensive sh*t?
- maggsy
Re: fuel
i dont think the car will die on you if you use e10 but premium is reccomended for the fto, it runs better is cleaner and gives better performance.
Re: fuel
Short answer is the majority of us wouldnt.
Also you will get more km's out of premium so the savings are redundant.
Re: fuel
BP 98 Ultura work well
Re: fuel
and your silly????Kustom_FTO wrote:put e10 or 95 in your car and your silly. 98 ONLY.
- Supplanter
- Gholdwayne
Re: fuel
hhakan wrote:I get the point no more tight ass fuel. Only expensive sh*t.
That expensive sh*t will get you more km's than the tight ass fuel buddy. You'd need more tight ass fuel to get the same km's as you would with the expensive sh*t so...
FTO's and most imports are meant to have 100RON as that's what they regularly have in Japan and we have 98RON so even with that, the car is 2RONs short - No biggie but it does the job well still.
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- Shane001
Re: fuel
http://www.unitedpetroleum.com.au/index.asp?pgID=65
Though you would probably need a piggy back to run this as being 10% ethanol you would probably need to pump in a bit extra to maintain a safe AFR...
- Gholdwayne
Re: fuel
^ Wow I didn't know we now had 100RON at servos! Just need a bit iffy on the ethanol there.
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Brodz
Re: fuel
out of curiosity.. how many km's do you normally get out of a tank using 98??
i have a 95 tip gpx, and i only put 95 in it... pretty much cos 98 is just too pricey for me. but am interested to know the difference in distance you get out of the fuel
- Gholdwayne
Re: fuel
Wait, what ?!Shane001 wrote:Ethanol is good, allows you to run more timing advance
I'm still a bit ignorant with the ethanol stuff and it's effects on the engine... But are you serious? And what is timing advance?
At the moment, maybe with an old fuel filter, full exhaust, full intake, I get about 450k's normally on BP 98.Brodz wrote:out of curiosity.. how many km's do you normally get out of a tank using 98??
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
