fto engine mount
dweebies
fto engine mount
Post by dweebies »
hey guys ive been having trouble finding an engine mount that looks like this for my fto
all the ones ive looked at have 4 bolts this one has 3 i have like a headache over this its the left hand side engine mount under the battery
Re: fto enigne mount
Where abouts are you located? Auto or manual? You replace the rubber section only, not the whole thing.
dweebies
Post by dweebies »
im in sydney ive been trying to find like the whole alumminium transmission mount =='
its auto so your saying i only have to replace the rubber inside of the mount cos its gone LOL like totally destroyed
Yup, that whole rubber bit is an insert. Go down see the guys at Meek Automotive & see if they can match you one up.
http://www.meek.com.au/index.php?act=viewDoc&docId=2
Once you do, let us all know which one fits!
dweebies
Post by dweebies »
would you happen to know of any other places that sell the rubber insert near liverpool?
EscapingFate
Post by EscapingFate »
You could try a jap wreckers... tahts where im going for my gear shifter bracket that broke.. theres one in wenty.
Bennoz wrote:Yup, that whole rubber bit is an insert. Go down see the guys at Meek Automotive & see if they can match you one up.
Bennoz this Mackay insert has the exact same dimensions as the transmission mount which looks to be the same as the right mount.
http://www.eziautoparts.com.au/mackay-e ... a5522.html
Good find! You gonna try it out?
Re: fto engine mount
Maybe?? Also found inserts that are actually exactly the same looking as the oringinal left right mount!
http://www.rhdjapan.com/ralliart-engine ... v-vi-51904
70 bucks delivered!!
The mackay mount is actually now listed on meek!
Are the mounting holes meant to be slow low? My ones are more near the center! Sort of explains why my bottom mounts are saggy!!
Here is the meek mount which looks the same as the Mackay mount A5522
http://www.meek.com.au/index.php?act=vi ... ductId=524
Mckay (If I measured right!)
Specs are:
89.2 (Outside diameter of housing)
12.5 (Hole that bolt goes through)
82.0 (Length of Tube)
54.00 (Outside housing width)
Got the exact specs Bennoz?
I don't sorry mate & I haven't got one spare here that I can mic up. Ayone got one of these mounts lying around?
I've got a full set of manual GPX ones, not much help here though...
Lawso
Penis Fingers
Post by Lawso »
i have a manual gr off a 6a13, straight fit ;)
lawsochap wrote:i have a manual gr off a 6a13, straight fit ;)
Yeah but that was the whole mount, not just the rubber insert ;)
Bennoz wrote:I don't sorry mate & I haven't got one spare here that I can mic up. Ayone got one of these mounts lying around?
The left and right inserts are the same. From looking at the pictures my left and right mounts inner tubes have moved more towards the center of the bush so my hole engine is sagging 1-2cm causing the rear mount to break! As 1-2 cm on the small rear mount would cause massive downward pressure on it.
I'm going to get one of those digital rulers to get a better reading on the dimensions and see if the mackay mount will fit. I am 90% sure the mackay mount will fit. I am pretty sure the mackay mount is the same as on the meek website.
I'm guessing if any FTO owner has not replaced their left/right mounts it will be sagging like mine.
