120k Service.
120k Service.
Okay so, my cars coming up to 120k :( :( :'( ! Dammit I really wanna keep her low on K's but can't stop driving her!... anyway.
I have had a brief look over what has been replaced at the last service and have decided I want to do the following, so I know it's been done and I don't have to worry about it... for the time being.
I've got a few questions i've placed next to the items. If you guys could help me out here it would be greatly appreciated :)
If I've missed out on something else that I should be doing, please let me know. :lol:
Let me know if any of these part numbers are wrong or you recommend something different ;)
Code: Select all
ITEM		                         		TYPE			         		PART #
Oil                            	     Penrite 10w semi sythetic 5L        	-
Oil Filter			                    K&n oil filter				        HP 1010 or HP 1006
Fuel Filter			  	              Ryco Fuel Filter                       Z441
AC/PS Belt			                	Power Steering/Aircon Belt 	         6PK1080
Alternator Belt	        	         Alternator Belt      	                4PK940
Manual Transmission Fluid           ????? Any recommendations ?
Spark plugs                           Recommendations?
Ignition Leads                        Recommendations & Where else, other then Camskill?
Slotted Rotors                    DBA425S/RDA425S   <--- DBA or RDA? Which one, and could someone send me in the right direction to grab them @ the right price?
Coolant
Themostat
Thanks guys
Re: 120k Service.
hey mate, regarding brakes, I've got slotted RDAs on and they are great, however if you have the budget, apparently DBA are the better option.
Also when you do your fuel filter, be sure to put up a detailed and photo-ed DIY for the rest of us to go off ;) :lol:
Re: 120k Service.
bass_twitch wrote:hey mate, regarding brakes, I've got slotted RDAs on and they are great, however if you have the budget, apparently DBA are the better option.
Okay cool, so DBA > RDA ? No worries bout filter ;)
Re: 120k Service.
DBA is better, RDA is just like a standard replacement, i can get you two new front rotors for $100 RDA.
Re: 120k Service.
silverGPX wrote:DBA is better, RDA is just like a standard replacement, i can get you two new front rotors for $100 RDA.
That's pretty cheap, however is that slotted?
And as for RDAs being the same as standard, personally I've found my slotted RDAs to be much better than the stock rotors...
Re: 120k Service.
May aswell go for the DBA then ;)
Re: 120k Service.
i just have standard rdas. with new front pads, they pull me up just fine
Re: 120k Service.
BUMP. Where can I get ignition leads from guys?!
Re: 120k Service.
your mum
Re: 120k Service.
silverGPX wrote:your mum
Besides camskill is there anywhere else?
mr-charisma
Re: 120k Service.
Post by mr-charisma »
Re: 120k Service.
Cheers bigears
yotka
Re: 120k Service.
Post by yotka »
NGK Platinum Spark plugs ( PFR6G 11 )
However, they seemed to have been superceded and the replacement is : BKR6EIX-11 and are about $19/- from WA's AutoOne.
