Redline Shockproof gear box oil, what 'weight'
- SilentBob
There are 3 different weights of Redline Shockproof's gear box oil...
which one suits the FTO?
Lightweight, SuperLight or Heavy???
SilentBob
SilentBob
- SilentBob
Ive hunted around newcastle with no luck, the 2 'stockists' dont have stock because of some supply chain change occuring...
UniqueAutosports has it in stock, spoke to one of the guys there this morning who said the 'lightweight' stuff was the right one, price was 29.95/litre and i think youd need 3 containers....
SilentBob
SilentBob
- smorison
- The Godfather
fto12345 wrote:And has any one changed this them selves?
Thanks,
its pretty easy to do... there are instructions in the technical documentation on how to do it...
again i'm lazy and go to UAS and use their highpressure pump (it's a vacuum attachment to their compressed air supply) and do it that way. doesn't take long and they won't charge much to change it
- payaya
mitsubishi boxes are damn picky when it comes to gearbox oil!
make sure they are within spec, also i reckon its damn expensive for a oil change using redline if you have a tip box!
If you do have a tip box, if its running fine, why change to redline? To do a complete flush you'll need over 6 litres, so over 200 bucks in oil, when its not necessary.
- payaya
