A few problems...
Miv3c
A few problems...
Post by Miv3c »
hi first off i have a 1995 Mitsubishi FTO GPX and i have a few problems
first off i the steering pulls off to the left not sure what it is ive just put up with up
next the brakes feels a bit weird when i press the pedal down i have a area of nothing then it grabs and they work fine other than that
jwa
Re: A few problems...
Post by jwa »
steering pull to the left, you probably need a wheel alignment, it should fix
if it doesn't work, bush maybe worn.
1. Can be many things
- bushes
-tyres (most likely)
-shocks
-brakes (may be related to brake issue)
-A wheel alingment wont cause an FTO to pull left or right as there ar no adjustment to do so (only front toe and rear camber/toe) It will only affect how the car handles eg: responsive or dull steering and tyre wear.
2. Brake calliper may be seized (relating to pulls left)
- also most probably due for good bleed and fluid change, its something that most people tend to neglect but should be done at least every 12months
