no spark
no spark
hello i got an fto i try to start it and all the sudden it wont start no spark comes out the spark plugs i cheked all the fuzes they seem to be fine would anyone know what the problemn can be its a 1995 gpx mivec thankyou
- SchumieFan
Re: no spark
what do you mean no spark?
does the alternator turn the engine over? ie, does it crank?
- brad_gpx
Re: no spark
the sparkplugs are still in the boxes?
- brad_gpx
- Kustom
Re: no spark
brad_gpx wrote:did you press the button to disable the immobilizer?
Re: no spark
the battery is alrite it cranks how to i disable the embolizer please
Re: no spark
Kustom_FTO wrote:brad_gpx wrote:did you press the button to disable the immobilizer?
how do i disable the immobilizer thankyou
- bduffman
Re: no spark
Depends my car dosent have one its only if you have a alarm system ( the unlock button ) will disable it but im sure u did disable it if you have a alarm other wise your alarm would have gone nuts when u opened the door
Check all grounds ( won't turn over if there's a ground not grounded )
Check that your getting power trace your way forward or back along the line
