no power at all!!!!!!!!!!
OK I went to start the car to put it away for the night, turned the key every thing started (dash, fuel pump and so on) then every thing went dead :?
I have checked battery full charge, all fuses are fine, battery leads are fine, battery cut off switch is on.
I have even tried to bypass the battery cut off switch but still nothing.
The only other thing I think it could be is alarm kill switch's, but I can't even work the alarm :?
Any one have any other ideas?
Re: no power at all!!!!!!!!!!
no power to anything at all?
nop nothing at all :?
do your headlights work?
no nothing works at all not even the clock.
brad_gpx
Post by brad_gpx »
emp
AJ
Post by AJ »
It has to be either a fuse or your alarm then if the battery is fine. What do you mean you can't use the alarm?
I've got a jump start kit that I could give you a jump with to see if that helps. Where are you?
I am at home, I will try a jump tomorrow but I don't think its that, but thanks for the ofer AJ.
as for the alarm it wont turn on or off, I have changed the battery in the remot but still nothing :?
AJ
Post by AJ »
aza013 wrote:I am at home, I will try a jump tomorrow but I don't think its that, but thanks for the ofer AJ.
hmmm, well give me a call tomorrow night and I can try mine for you anyway.
brad_gpx wrote:emp
Its the alarm. Same thing happened to me last month. Youll need to get the alarm cut out or repaired.
    I reckon it's bad earth. Twist your battery terminals around a bit & check the neg earth lead grounding.
    Well after ripping 1/2 the car apart checking every thing I moved the earth lead off the strut tower to a new spot and what do you know the car is alive :lol:
    Battery side of things was fine, alarm was not a problem.
    :lol: @ Ben you are right again :lol: but I only seen your post after I fixed the problem.
    FTO-BOY
    Post by FTO-BOY »
    Funny thing this happened to me this morning
    ...Fluke ben.
    topgun
    Approved FTO Australia Trader
    Post by topgun »
    Kustom_FTO wrote:...Fluke ben.
    I didn't get to the top guessing, you n00b! :lol:
    Bennoz wrote:I didn't get to the top guessing, you n00b! :lol:
    Sure buddy
    No, he just payed out the rest of the mods.
