Do the Mivec and Non mivec Cam Gears Differ?
Do the cam angle sensor adaptors differ either?
After talking to them today they claimed that the cam angle sensor was different on my mivec, Gears and sensor from a GR. and that even adjusting the sensor the adjustment they could get wasnt enough to allow the sensor reading to be in line with what it was meant to be.
in this post and pic below shows the cam gear in question as well as a rant from bennoz pulled from my thread.
i really want to put these on we just have to know what went wrong and blame them for their inferior knowledge so they put them on free or reduced charge which would be awesome!
thank you guys
Bennoz wrote:I still fear for you at that mechanic![]()
Take a close look a this picture:
Why is the inlet cam (left) is fully retarded when the exhaust cam (right) looks to be set around 0???
All your cams should be set at 0 to start with. Its no wonder the bloody thing wont run properly, you may as well have got the timing belt off by 2 teeth...
I hope you realise too, that if they put the stock cam gears on, that means the entire timing assembly has to come off again & cam belt has to be reset again... there's a good 4 hours worth of work in that... at least.
