how to change idle
how to change idle
Big problem, cant change idle from lever near the windscreen (forgot what its called). is there any way to change it?? its currently idling at 1500rpm.
- Boris
Is that with or without aircon?FTOluv wrote:Big problem, cant change idle from lever near the windscreen (forgot what its called). is there any way to change it?? its currently idling at 1500rpm.
The lever near the windscreen do u mean like the linkage? Where your throtle cable comes in? (I hope its called the linkage
There is a small gromet/plug half the size of a 5c coin on the right top part of your engine, where the air intake piping comes in, with a little screw to adjust the idle... It's just a bit down from the linkage from above, i think.
Is that the screw that you have been using?
i just put a new coil pack in becuz the other one was cactus. before i had to make the idle higher in order to keep it at 700rpm now ive tried to put it on the lowest and its still idling really high.
The air con is off. that screw on the side is really hard to turn im not sure if im even turning the right one!
- payaya
you put a new coil in your stepper? you sure you did it properly?FTOluv wrote:i just put a new coil pack in becuz the other one was cactus. before i had to make the idle higher in order to keep it at 700rpm now ive tried to put it on the lowest and its still idling really high.
- RT
- RT
- smorison
- The Godfather
try cleaning your stepper motor first... i have an RSM i notice over time my idle drops from 750 (factory setting) down to 650-600 as the stepper motor gets dirty...
one time i was using the idle screw to adjust the idle on the car without cleaning the stepper motor ... eventually went to clean it and idled at 1500rpm...
to clean your ISC all you need is a 10mm socket a screw driver and a can of wd40 and about 20-30minutes...
the factory settings for idle are 750rpm +/-200rpm ... there's no need to set your idle at anything more than 750 from experience and my car will idle happily as low as 600. (anything under about 550 and its gets a bit unstable).
- payaya
below the throttle body. You know where the air filter box is? Follow the plastic tube, then the plastic tube is connect to the engine right? Look under the plastic tube, and connected to the engine is a small motor like device. Its got a poweer connection to it, and is held in by two phillips head screws.
Thats the simplest way of describing where it is.
- smorison
- The Godfather
