"D" Light on Tip tacho not working...
- ellusion
I was fiddling with the dial console today to check out where the bulbs were and to get the hang to removing it in and out. I did not go anywhere near the lights for the Tip display of the dials.
However, the "D" on the tacho won't light up anymore. I've checked the bulb but it seems ok. Is there anywhere else i should check?
Where would i get this bulb if i did need a replacement?
- ellusion
oh yeh, forgot to mention that now ALL tip lights don't work...all the other lights do though some parts of teh dials are still working........ wats heppening????
Instead of my right indicator light in the dials flashing, now the odometer flashes!!! So whenever i turn right and indicate, all i see is the odometer screen flashing and no green signal... its all f*cked up...
It might also pay to remove the dash and check, clean and align the two sets of connectors (both the ones on the back of the main dials and the sockets they plug into on the dash).
I had a few dash light issues when playing around with the LEDs, but only because the plugs in the dial units weren't sitting properly in the sockets mounted in the dash. Unplugging, realigning and pushing it back in solidly fixed that.
MIVEC is My Friend :D
