Air Conditioning Problem
voltages
Post by voltages »
The unit was okay when i last used it. When i used the aircon the following day only the fan is blowing, no cool air. The compressor does not start, i looked at the fuse but its ok, what could be a possible cause?
One more question, does frequent starting and stopping of air conditioning unit affects the air conditioning unit life?
Thanks for any help.
Voltz
-Nighthawk-
Re: Air Conditioning Problem
Post by -Nighthawk- »
Same problem was with mine, the auto electrician found some sort of switch or wire that was faulty, couldn't tell you which one sorry
voltages wrote:The unit was okay when i last used it. When i used the aircon the following day only the fan is blowing, no cool air. The compressor does not start, i looked at the fuse but its ok, what could be a possible cause?
Voltz
I reckon you'd be outta gas ;)
Compressor wont engage if the pressure isn't up.
^^^ this would be my first guess and starting point
voltages
Post by voltages »
@bennoz, what do you mean out of gas? is it the fuel gasoline?
The Air Con lines are pressurised with the refrigerant gas R134a (or R12 on older cars)
http://www.airconcars.com/html/how_it_works.html
voltages
Post by voltages »
i see, i will try to check the freon pressure with the mechanic, but previously the air conditioning is so cool before it conk, :)
voltages wrote:i see, i will try to check the freon pressure with the mechanic, but previously the air conditioning is so cool before it conk, :)
It might just be a slow leak, so when they regas it, get them to put in the fluro dye. Then when it leaks again, you can see where its leaking from :)
voltages
Post by voltages »
@nighthawk, @ bennoz, @I8A4RE thanks for your replies
No worries at all. Did you get it sorted?
voltages
Post by voltages »
Yes problem solved. Seems there is a problem in the filter and the evaporator valve, those two are stuck causing the evaporator to leak ( four identified leaks). We just gas weld the evaporator leaks and replaced the filter and the evaporator expansion valve. Leak test, vacuum with oil, re-gas and its done, hehehe. Caused me some bucks, lolz!
