Recommended Oil to use?
-Nighthawk-
Post by -Nighthawk- »
Hey,
Going to change my oil tomorrow and I was wondering what the best oil to use is, and something that isn't an overkill. Any suggestions?
I had a look at few and Mobil 1 looks to be good, but is it an overkill for my car?
cheers
zuihoujueding
Re: Recommended Oil to use?
Post by zuihoujueding »
hi there,
personally Semi-syn oils like Castrol Magnetic or Vavoline Durablend 10W-40 will be the least you want to put in for your engine. I would suggest Valvoline as there is promotion going on and i believeit carry over to all its range so if you want to go further, try SynPower.
Mobil 1 is great but you could have bought 2 bottles of semi-syn oil change twice as often which ends up even better for your engine.
Serch button ftw.
There are a sh*t load of posts on this topic.
Mobil 1
xj265
Post by xj265 »
+1 search button
-Nighthawk-
Hmm I accidentally purchased Mobile 1 5-30W, no idea what this "W" is but is that good enough for my engine? Or should I return and get a better one?
cheers
I run a 5w30 with out any problems.
SmokeSolid
Post by SmokeSolid »
Mobil 1
spency
Post by spency »
5w 50?
Valandis91
Post by Valandis91 »
Martini Racing 0w-40 :D $80 for 5 Litres.
Valandis91 wrote:Martini Racing 0w-40 :D $80 for 5 Litres.
Any particular reason or just because you can?
Valandis91
its quality stuff. engine is running much smoother on it. plus its good for cleaning out the engine as its a bit thinner but has other lubricants added to protect the engine.
less tappet noise from me as well.
its ok for me cos its cold down here so not sure if its ok for melbourneans
Use penrite semi-synthetic 5w-40, its not retardly thin and its safe, if u want an even safer option go the 10w-50. dont go thicker or thinner. 0 weight is just dumb, 15w is getting too thick.
+ its well priced.
Valandis91
silverGPX wrote:Use penrite semi-synthetic 5w-40, its not retardly thin and its safe, if you want an even safer option go the 10w-50. dont go thicker or thinner. 0 weight is just dumb, 15w is getting too thick.
gee you have issues. look in the uk plenty of people use 0w
i thought it snowed over there?
spency
Post by spency »
Snows down here too, had it down to 300m last week
zuihoujueding
if you check on the lube guide on major engine oil companies, all recommends at least of 10W.
This ^
I've just been using Shell Helix Ultra 10w40. Seems to cope with 200+kws without issue.
zuihoujueding
is there 10W-40 in ultra range? nearest is 5W-40 isnt it?
you should be referring to HX7?
